125-200cc HElP NEEDED
Discussion in '2 Stroke' started by Husky Borris, Feb 17, 2013.
  1. Husky Borris Husqvarna
    Fareham
    Right yesterday started my bike up and loads of smoke came out of the exhaust I also have to move the kick start up and down to gain compression. I've also started it today and the is now and greenish yellow liquid coming out of the exhaust can anyone help ???
  2. Ex HVUK Husqvarna
    England
    None
    Sounds like a head o ring failure, coolant in the cylinder. Time for a top end rebuild unfortunately.
    Dave
  3. Husky Borris Husqvarna
    Fareham
    Would that be a full top end or just piston?
  4. wallybean Mini-Sponsor
    Montana
    Is your bike an SM or WRE 125? The reason I ask is that I had an WRE or SM cylinder sent for a 165 and had it bored/re-lined to 165 before I realized it was not going to be the same as the WR/CR125 cylinders port timing wise. If you do need to do a total top end I can probably make you a good deal on that cylinder.
  5. gixxer1340 Husqvarna
    93 cr125
    91 Suzuki GSXR750-1340cc & GSXR1100
    Yea, what HVUK said. Piston might be ok. Inspect everything! At the least you'll need gaskets/seals for top end and I'd re-ring it if piston to cylinder clearance is good. I'd drain the coolant, crankcase oil and pull the clutch fibers out and soak them in fresh crank oil while waiting on parts.
