Help Needed
Discussion in 'General (Main)' started by Ruffus, May 28, 2015.
  1. Ruffus Husqvarna
    Just getting ready for an epic 3 day ride & bike wouldn't run worth a damn. Finally found the problem, intake rubber is cracked.
    Anyone know where I could locate a new carb intake for a 2006 Husky TE510 in a hurry?
  2. Norman Foley Husqvarna
    Hall's, Bill's or Motoxotica are your best bet. Also try Up-Tite.
  3. Ruffus Husqvarna
    Thanks Norm, time to start searching.
  4. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Red hi-temp gasket sealer, real thick, spread wide, works in a pinch.
    ray_ray likes this.
  5. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    Nooooo! Where you headed, Dan?
    Hope you get fixed up in time.
  6. Ruffus Husqvarna
    Roaming Rally is done for another year:thumbsup: . My team mate sourced an intake at "Oneals" in the Rochester area. Incredibly they had it in stock, so the trip went on:banana: .
    In hind site, maybe it would have been better not finding the intake manifold.:D
    So what are the different reasons a bike would stall out in knee deep water, even crotch deep, but not taking any water in the carb & the vent tubes are routed up high? After a few hours of research, I wondering if I set up the vent system properly, I ran the hoses up under the top frame rail, using an "UPTITE" filter, but running the single line back down to the original spot. Could that do it? I'll try putting the line in a cup of water & see if it kills the engine. Really, really hoping it could be something that simple.
    I'm guessing I need to take apart the electrical system apart
    .& dielectric grease everything to eliminate as many of the possibilities to drown out as there is., is there anything else I should look at?
    Thanks for your time brothers & sisters. Any info on making my bike a semi submarines would be much appreciated.
