please can anybody shed some light on part nos for asv brake and clutch lever for a 2008 sm 610 application...
Hey there miccharlton I’m just going to quote JSArcher from the “610 pic” thread and below is his bike, not sure what year it is but at lest it’s a start
I used that same lever set up but with a hot start lever. I used the hot start lever for the choke, it took a little fussing with but it works well. Do a search for 610 ASV levers I think you will find some additional information. Dan L
thanx muddy dan .... do you have a pic , will that lever on js archer bike not support the choke on the 2008 model, looking at it , i cant see the choke , must be a carbed bike then . dan can you give me some more details on this hot start lever please
I used a CMF-30-? The ? = R on the one I got. I think R is supposed to = Red, but the one I got is black. That maybe why I got it cheap on ebay. This is on a TE but I think your clutch is the same on the SM. Sorry I didn't do the brake, can't help you there. Here are a couple of pics. You can see the hot start used as the choke. I had to make a little spacer out of fuel hose. I won't do that on the clutch that is used alot, but it works fine for the choke. You will need mirrors that mount to the handle bars.
well my asv brake arrived and the perch wont mate to my master cylinder housing, ? does this mean ,junk the ms and install a ktm 1, or am i just plain stupid
thanx kw ... would you no what year bike that cme from? also what did you use for the clutch side...any info would b app thanx mic.....
I for got master is 98 to 2006 525exc and part # for clutch is clm01 also needto drill out for cable end, use barnett cable can buy at halls cycles
