Help with Compression shim stack
Discussion in '610/630' started by dubbs, Jan 1, 2012.
  1. dubbs Husqvarna
    Ontario
    I'm putting in the adjustable compression adjuster on my '08 TE 610 forks. When I have it apart does anyone have a good set up for the valve stack for the compression adjuster? I'll take your rebound numbers as well if you have them. The bike will be uesed for a mix of trails and road.
    If you could list your shim stack and oil weight and level that would be great.
    Thanks.
  2. johngil Husqvarna
    Reseda, CA
    Still waiting for my parts. Hopefully I'll know soon.
