Hey guys,even though I feel really stupid asking this,I'm gonna anyways. So I pulled the tank off trying to swap out my stock ignition for my new FBF dual mapping ignition with switch. First issue is the new ignition has no bolt holes to mount to the frame as the stock one did,it's just a square box.Second problem is the wire plug connects into the new one,but I can't see where the 2 tiny connectors coming from the handlebar switch Connect to the ignition itself?
You should have gotten a little diagram that shows which spots on cdi plug to install them. FBF can help you with this if you give them a call.
Well,that's one problem because once the plug is connected,there is no where else the two tiny switch wires can go.
Actually you pull the little rubber plugs out of the back of the connecting plug and insert the two little wires in the appropriate holes.
