Help with light bar mounting
Discussion in 'TR650' started by LED, May 14, 2016.
  1. LED Husqvarna
    Perth, WA
    TR 650 Terra
  2. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
  3. LED Husqvarna
    Perth, WA
    TR 650 Terra
    Thanks Nev. Saw that but it would mess with my screen. May have to rethink and go for individual LED lights instead.
  4. Cyntax Husqvarna
    The Netherlands
    TR650 Terra, 900R Nuda
    MG V50 NATO III
    Not sure what kind of screen you have but if its the OEM one then there is more than enough room to fabricate something so that the LED bar would be in front of the screen right above the regular headlight.
    I used a thick plate of regular weave carbon fiber and cut the brackets out of it with a Dremel. Then I mounted the brackets to the top triple tree clamp just like other TR650 owners did before me. Carbon Fiber barely fatigues and is extremely ridged, I bet it could hold a 2 kg light bar, you just need to fabricate a thick and wide bracket for it to reach in front of the windscreen. I have two SW-Motech full aluminium bodied LED off-road lights hanging on those brackets with no trouble at all.
  5. Johnn Husqvarna
    Newcastle Hunter Valley
    T4 Moto Guzzi
    Fascinated the unusual side saddle arrangement on the Guzzi.
    Cyntax likes this.
  6. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    You could build brackets that bolt to the lower triple clam, and have the light bar under the headlight.
    In many states, aux lights have to be below the factory headlight, or covered while on the road.
  7. snail_72 Husqvarna
    Cairns Queensland Australia
    Tr 650 Terra
    KLR 650
