Help with slide / pics (2 stroke)
Discussion in 'EFI/carb' started by JPinNC, Jun 19, 2015.
  1. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    Doing some projects with my son this weekend on his RM125 ... not Husky but thought someone here might be able to give some advice - slide is perfect except for two spots at top of slide, they really don't look like areas of wear, rather they look like areas where the slide did not get fully chromed or maybe pitting in the chrome?, first picture is not so good but you can see the copper color showing through ...
    The slide is smooth as silk when opening and closing the throttle / any concerns, need to replace slide ?
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    odd, i have seen many slides where the plating has worn thru from dirt/age/wear but that looks like a defect. as long as its smooth to touch i would certainly not worry about it as it wont affect anything. ive never seen a single pock mark like that tho, especially when rest of slide looks almost mint.
    perhaps if it kept spreading you could swap in a new slide but its fine if it stays the way it is, imho. many have run slides looking much worse, lol.
    R_Little and JPinNC like this.
  3. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    i agree run it
    JPinNC likes this.
  4. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    Carbs all buttoned up ... will keep an eye on it; thanks for the replies
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    That is only the chrome separating from the copper underneath.
    Should not be an issue.
    JPinNC likes this.
  6. justintendo klotz super techniplate junkie
    arent they brass?
  7. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    PURDY SURE :thinking: THE COPPER IS PART OF THE PLATING PROCESS:excuseme:
  8. Shovelhead85 Husqvarna
    Northern NorCal (California, USA)
    2014 TE 310R
    XR400R, '75 DT400B, FLH Shovel, CT90
    Possibly got acid on it?? Anyway- polish it up, run it.
    good luck.
