TE/TC Help with TE300 gas tank
Discussion in '2st' started by Snel, Oct 1, 2014.
  1. Snel Husqvarna
    TE300
    KTM 300 EXC
    Hi Guys,
    I am irritated how Husky has in the owners manual the gas tank listed at 10.7 L or 2.83 G. Soon after I got the bike I drained the tank and filled it up using a 2 liter Coke bottle. With the bike standing up right, I marked the level on the tank with a sharpie after each 2 liter bottle added. The tank was fill after a little over 8 liters. The manual says it takes 10.7, so I thought I had somehow forgot to mark the tank after adding a bottle somewhere mid tank. I did not feel like draining the tank and double checking, just put it down to a senior moment and left it at that. I thought I had read somewhere on this site someone had stretched their tank and now holds 3 gallons. Decided to stretch my tank as a decent ride I would use a whole tank plus 2 two liter Coke bottles of gas and barely make it back to my truck.
    With the tank empty and in place on my bike, I filled the tank with boiling water let it sit for about five minutes then pressurized it. It did not hold much pressure before the air escaped from the gas cap. The tank expanded mostly on the larger side with the petcock. The next day I laid the bike on it's side and only filled the smaller side with boiling water and pressurized it, hoping to get the tank a little more symmetrical. The end result the tank does not look too bad. It is a little wider, you can feel it when siting on the bike.
    So I was hoping for about 13 liters (3.4 gallons) as I thought I was starting at 10.7 liters. Filled the tank again using a 2 liter Coke bottle and marking as I went. To say I was unhappy and disappointed would be an understatement, when I found the tank only holds a little over 10 liters. Made me start thinking how much does a 2 liter bottle hold, so I measured and found I was over filling the Coke bottle a little each time. So I am thinking the tank holds about 10.5 liters (2.77G).
    So my questions are.....Has anybody on this site stretched a TE300 gas tank so that it actually holds 3 gallons. If so what did I do wrong?, I even added a rubber gasket made out of a bicycle tube to the gas cap so I could add more pressure. Does anybody know of any after market tank that will hold 3.5 to 4 gallons that will fit our bikes.
    If somebody can tell how to add pictures, I will add some.
    Thank,
    Sean.
  2. Norman Foley Husqvarna
    Simple solution... Aftermarket tank for a late model KTM and some white KTM radiator shrouds. Craig Delong ran this combo, with PG graphics.....
    BILLF and robertaccio like this.
  3. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    those checks are embarrasing,,,,,,,really
  4. Benjimoto Husqvarna
    Lincolnshire, UK
    TE 300
    KTM 150xc Hypermotard sp
    WTF!!! Buy a bigger tank! Simples!
  5. joedirt Husqvarna
    PA
    wr250
    The "A" classes don't get paid at a gncc unless you are top amateur.
  6. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    CHUCK SUN HAD THE SAME GAS TANK AND SHROUDS ON HIS TC250 SUNDAY AT THE FLYING M RANCH RACE.LOOKED GOOD.
  7. Motosportz CH Sponsor
    Why is there no big tank option for the Huskys?
    Sure you can buy a tank, shrouds and graphics, your in it like $450 and the rad shrouds don't line up with the rest of the plastic. Silly there is no factory or aftermarket option by now. I'm I missing something here?
  8. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Nope, especially if you are mindful that Husky is supposed to be second fiddle to the "Race Ready" KTMs
  9. Motosportz CH Sponsor
    Well they seem to be selling really well so why not tank options?
  10. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    I think there is a missing zero at the end...;)
  11. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    IMS is making the tanks. John-Erik said no to any of the factory teams using KTM tanks and shrouds, irritated with us apparently too.
    BILLF likes this.
  12. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    Just quit making them look bad. Throw a few races and let the KTMs get more places ahead.
    That should make them happy...right?
    BILLF likes this.
  13. Norman Foley Husqvarna
    Husky USA under BMW was just as slow getting tanks for X-Lite and 125's in '09. I spent a good bit of my time and money, trying to move the process along with P3 to no avail..... Had fun with Lindsay Pirie, cool guy!
  14. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Hey man, if you were a C rider and lived 1/2 mile from the track you could almost pay your fuel and entry fee with that massive check.
    shawbagga and robertaccio like this.
  15. Parkeshusky Husqvarna
    Te300
    250exc-f xr650r
    I'm in Aus and found the exact same issue I went back to husky Australia and said it was false advertising and the 10.7L tank is now on it's way to me. Seems that Australia isn't only country with issue
  16. Snel Husqvarna
    TE300
    KTM 300 EXC
    Parkeshusky, do you have to send your old tank back after you receive your new tank? The reason I ask, I've stretched my tank already. I think I'm going to try contact Husky USA. Hopefully I will get the same results, see what happens.
  17. Huskyfatman Husqvarna
    So.Nv.
  18. Norman Foley Husqvarna
    I'm really curious, what tank Husky Australia is sending Parkeshusky? Were some tanks molded incorrectly and now they are right? It will be a big bummer, if the new tank is the same one.....
    Motosportz and LandofMotards like this.
  19. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    that cheque would have had to of cost at least $100 to make wouldnt it!:lol:
    454x and robertaccio like this.
  20. fletchman45 Husqvarna
    park rapids
    OK OK I'm having a Te tank installed on my etc. Is this a stupid move??? I thought the Te was rated at 2.9 gall????? Am I wasting $200????
