Help with wallowed out foot peg holes
need2boat
New owner of a 2012 TXC 310 with some good millage on the bike and need to take care of a few things. The first of which is wallowed out peg holes as well as some wear on the bottom side of the peg perch. The perch I'm confident I can build up worth a few tack welds and grind flat.
The wallowed hole however I wasn't sure the best way to fix. I did some searching and found that some drill them out and use a larger pin but I'm thinking a washer or bushing with a collar might be the ticket if I could find one in the right size.
If anyone's been here and found a good solution I'm all ears.
Joe
Just wanted to follow up in this for those of you that run into this. I looked into getting larger pins but decided to just to weld the hole in a little and file out it back out. Not the fastest process but it worked great.
Joe
The bike is a 2012 with 100 hours on it. The first ownerChris Gosslin from SC is a AA racer and known to be hard on bikes. The second owner didn't really do much other then change the fluids and put about 10 hours on it. I bought it for a very good price eyes open knowing it needed some TLC after Chris.
I haven't met him just googled and he looks bigger then me. I'd say I90 to my 175 but I guess all the time in the pegs had to toll. In addition to the pegs he wore the hole in the pegs and even the pins.
I had a friend weld in a few beads and I just took my time and filed as needed. They may not look great in the pictures but the fit is dam near perfect. I also added a tac at the bottom so I could add a little angle. When the paint dries I'll take a pic with the hardly used pegs and pins I got in ebay they look as good as new.
You can't see it in this pic but I've got the tank off it and I'm handling so less then kind wiring hacks he did. The bike was wired with click on/off for the fuel pump and a momentary switch for starting it. I've been having issues with both so I just ordered some new ones and I'll clean up the wiring and everything should be fine.
Joe
