250-500cc Help with WR300 Headlight
Discussion in '2 Stroke' started by fastkx125, Dec 16, 2014.
  1. fastkx125 Husqvarna
    Long Island, NY
    TR650
    I'm picking up a new WR300 USA spec as I am from NY. I cant seem to find a concrete answer on how to run a headlight, maybe a tail light. Id like to use all LED to keep the load down and the usable light up. Do I need a second aftermarket regulator/rectifier? The stock system (yellow wire?) is AC? I don't have the bike yet so I haven't gotten a chance to tear into it. I don't want to damage any of the OEM electronics because I know this euro stuff is pricey and hard to get. Id be fine with one good LED headlight. What do you guys think?
  2. WVdag Husqvarna
    Smithville, West Virginia
    2007 WR250 W/300 kit, 2013 CR125
    1987 Harley FXLR 10th year edition
    I have an 07 wr250 and have a poly sport led head light on and it works good. Running through the oem regulator.
  3. Al H Husqvarna
    Australia
    WR250 2001
    BMW R1150GS 2001, KTM620
  4. fastkx125 Husqvarna
    Long Island, NY
    TR650
    Straight off the yellow wire?
  5. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    ^different ignitions(kokusan analogue vs ducati energia digital i believe) keep in mind. ducati not much chop for running/starting with lights etc. as opposed to kokusan. i havent checked but i thought the ducati still ran through a reg/rec?
  6. fastkx125 Husqvarna
    Long Island, NY
    TR650
    It has a Reg/Rec on it I believe. I pick up the bike tonight. I'll break out a multi meter and see what's going on in there.
  7. fastkx125 Husqvarna
    Long Island, NY
    TR650
    As per the manual it has a 12V 110W generator. Generator means DC voltage right? Maybe thats for aircraft only (Generator vs Alternator) and it has 35W headlight, 3W taillight, 21W stop light, 10W instrument cluster. So if I want the Baja Design Squadron headlight and a simple LED tail I'll prob be ok right? Just gotta figure out what voltage I'm making.
  8. Husky Gordon Husqvarna
    WR 300
    KLX 400r
    I put lights on my 2009 WR 300 and I bought the factory Rgulator/Rectifier and installed it. No problems with hthe lights and I run them all the time.
  9. fastkx125 Husqvarna
    Long Island, NY
    TR650
    The one thats on my bike? Where did you wire them to?
  10. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    I have read that you need to have the lights "switched off" to help with starting. Do you guys have switched lighting or are the lights hot all the time?
  11. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    That's with the Ducati ignition found on '11+ models. Mine would normally start one kick, but would be a bear to start if I left the light on.
  12. Husky Gordon Husqvarna
    WR 300
    KLX 400r
    we used the yellow wire from the stator. My 09 starts fine with the lights on,.
  13. fastkx125 Husqvarna
    Long Island, NY
    TR650
    OK I called Baja designs and ordered the DC kit with all the goodies. I asked for the sII light but in the email I got it looks like they are sending me the Squadron Pro that's the 4 led light that draws 44watts instead of the 22watt light I asked for. Do you think Thats to much of a strain on the charging system?
    Cosmokenney likes this.
  14. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    I wouold think your ok. I run a trailtech h2 light , trailtech explorer, gps, heated grips and tailight/blinkers all the time and neve an issue.
  15. lankydoug Husqvarna
    MO
    WR
    TM 300en
    That's because yours is an 09 and is capable of 55 amps in stock form. Somewhere after 2010 they switched to the digital ignition and I don't think they do as well. The older ignitions don't require a resistor spark plug either so you can run a B8EG or a BR8EG and are extremely reliable. I think this is a case where older is better.
    Cosmokenney and 454x like this.
  16. fastkx125 Husqvarna
    Long Island, NY
    TR650
    Ok so I'm going to call Baja Designs Monday before they ship my order and have it switched to the S2 from the squadron. Thanks guys.
  17. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
  18. Marshall Deming Husqvarna
    New Mexico
    WR300
    several
    I just bought a 2010 WR300 that has no lights. I've been reading and reading the posts on this forum about hooking up to the yellow wire from the stator. My bike has four wires coming out of the stator: red, green, black/red, and red/white. No yellow wire.
    Can anyone please explain why there's no yellow wire on mine? Can I run lights off one of the wires I do have?
    Thanks.
  19. fastkx125 Husqvarna
    Long Island, NY
    TR650
    The yellow wire is under the tank.
  20. justpinit Husqvarna
    Maryland
    2012 wr 300
    93 kx 125 with a kdx 200 engine.
    My 2012 wouldn't start w the lights on , make sure the jetting is right , mine seized the top end. Throw the stock clutch cable in the trash , and be ready for back ordered parts...
