High Idle After Leo Vince and P/U Kit
Discussion in '610/630' started by rockitdoc, Sep 7, 2010.
  1. rockitdoc Husqvarna
    CO
    Idles at 2000. What's the deal? Tried turning the adjuster on the throttle body (the one BEHIND the airbox that takes the 8mm hex or phillips, that you can barely see). Ended up turning it almost all the way in (CW) until rpms began to increase a bit. Nothing changed after about 4 complete turns in, and never did the rpms decrease.
    :confused:
  2. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    Idle increasing after the PU mod is normal. I don't know about the idle screw not working like it should. Mine was just fine after installing the PU kit.
  3. ICBiker Husqvarna
    Emporia, Kansas
    09 TE610, 08 TE450
    I had the same problem with mine. It turned out that the choke/fast idle cable had worked it's way out of the 90 degree tubing on the side of the fuel injector. Put it back in place and then I was able to set the idle. Hope this helps.
    Glen
  4. rockitdoc Husqvarna
    CO
    I'll look tomorrow and let you know.
  5. High-Side Husqvarna
    Mine did the same thing. Are you sure you are turning the right thing? When I adjusted mine, I let it come up to full operating temperature and then made the idle adjustment. I only had to turn the bolt/screw a little bit to get it down to 1,600 rpm's. Did you have your enrichner all the way off?
  6. rockitdoc Husqvarna
    CO
    Yes. Enricher all the way off. I had just riden it 75 mis on the hwy. Plenty hot. But, one thing; I did have the air filter off for cleaning when I tried to adjust it. Maybe that? I'll check the enrichener to make sure, also, tomorrow. Too dark now.
  7. organ donor Husqvarna
    Berlin
    Mine too. Idle was much too high after the P/U kit was installed. You´ll need the special small spanner in the tool kit to re-adjust the idle. Doesn´t take more than a few minutes and instructions are in the manual.
  8. High-Side Husqvarna
    I'm not sure how much that would throw things off, but mine was on when I made my adjustment.
  9. T Stretch Husqvarna
    Sacramento
    This might be good news. I just took my bike in for a check up as I blew a fuse. They saw that my bike was idling high. They checked everything and what appeared to be causing the problem was the choke wire was too tight so it was keeping the choke on which was causing to bike to idle high. Try loosening the wire by the choke. It appears to be very tempermental.
  10. rockitdoc Husqvarna
    CO
    I looked at mine just now. When I 'engage' the enrichener, the cable pulls back and appears to be doing something. However, when I push the lever back to the original position, the right-angle thingy at the throttle body? kindof moves so it's difficult to tell if anything has changed inside.
    So...I disconnected the 10mm hex that goes into the throttle body? to see how this thingy works. Basically, its a plunger connected to the cable. When you pull back on the enrichener lever on the handlebars, it pulls the plunger away from what looks like a piston inside the throttle body. When you push the lever back, it should push the plunger back into the throttle body and engage the little piston inside. No way to tell if it actually does this, of course, after assembly.
    So, I don't know. Mine still idles too high, too. And, turns on the 8mm hex behind the airbox still have no effect.
    I hope I don't have to take this to a DEALER!
    S
  11. T Stretch Husqvarna
    Sacramento
    The dealer working on my bike loosened the cable all the way and it was still tempermental. If you take your hand and just move the cable back and forth you could hear the idle go up and down. This might be a flaw in the bike.
  12. jckid Husqvarna
    California
    Previsouly owned: SM610
    WR250X, KLX351, CT110
    My bike has idled at 1200 rpm since new. After installing the Leo Vince and PU, it now idles at 1500-1600 rpm. I haven't adjusted the idle yet, but from what I'm reading here, I take it I don't need to?? So is 1,500-1600 the ideal range?
  13. BadMotoWeazal Husqvarna
    Alabama
    My 2006 carb model idles well at 1800...anything lower than 1500 & the auto-decompression kicks in..FWIW
  14. ICBiker Husqvarna
    Emporia, Kansas
    09 TE610, 08 TE450
    Make sure the outer sheath of the cable is seated all the way into the 90 degree bend. You will have to slide the rubber boot out of the way and see if you can push it further into the tube. The end of the sheath on mine was caught on the edge of the tube and not inserted at all. I also had to reroute the cable at the handlebar because every time I would turn them all the way to the right the engine would speed up. It doesn't take much tension to affect the engine speed.
  15. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I don't know about the 610, but the 630 manual says idle should be 1650.
