Highway Dirt Bike Handguard and Lynx Fairing
Discussion in '610/630' started by Guoseph, Dec 19, 2011.
  1. Guoseph Husqvarna
    Alameda, CA
    FE501S
    Honda VFR800, KTM 525 EXC
    Has anyone installed HDB handguards with the Lynx fairing from Britannia Composites? Wondering if there are any clearance issues with the type of mount that HDB uses.
    Thanks!
    Alex
  2. Guoseph Husqvarna
    Alameda, CA
    FE501S
  3. oneleven Husqvarna
    2011 TE 630
    The HDB bars have a generic bend in them. You'll need to bend them in a vise to fit your handlebars, but it's not easy. Mine still take some muscle to bend them enough to get the bolts in. I find it easiest to bolt the ends of the handlebar first then push on the other end towards the top clamp. If you can't bend it to a perfect fit it will hit the display when you try to push it down (if you're using the stock Lynx mount location). Then you'll have to unmount the display, move it out of the way, bolt the guard down, and reattach the display. This is just for the left side. No need to remove the display for the right. And I switched out the HDB hex key bolts for 10mm socket head bolts. Using a little allen key to tighten those bolts got old quick.
  4. Guoseph Husqvarna
    Alameda, CA
    FE501S
    Thanks for the info!
    I don't have a vise, so this may be a little harder than I thought. I really dig the flip out mirrors though.
  5. Sorry for the lame garage photo but just wanted to say that I haven't had any issues on my set-up.
  6. Xcuvator Husqvarna
    Scholls Oregon
    yes
    If you are having trouble bending the handguards, annealing the area to be bent first will make it very easy and there is no risk of breaking them.
  7. mnb Husqvarna
    San Jose, California
    2011 TE310 . . . . 2003 TE610e
    Stick one end of the guard into a hitch receiver. Heat it up a bit with a torch first.
  8. Guoseph Husqvarna
    Alameda, CA
    FE501S
    Thanks for the tips. I don't have a hitch either :p
    I think I will order a set and see, these are exactly what I want minus the bending part.
