Hot start button to leaver conversion
Discussion in '4 Stroke' started by Sandgroper, Aug 24, 2009.
  1. Sandgroper Husqvarna
    Dubai
    Has anyone done this? if so could you help by advising what parts you used and possibly post pics :)
    :thumbsup:
  2. Poopy Husqvarna
    Kamloops, BC
    WB165
    Thats too funny, I just said that yesterday when I was out riding. My first thought is to use the decompression lever as the actuator, make some sort of bracket that bolts to the carb and/or motor. Thats as far as ive gotten though....:cheers:
  3. Sandgroper Husqvarna
    Dubai
    Haaa, well I read about it somewhere but I dont recall seeing pics. May have been in the DirtRider write up for the GNCC setup bike. Parts arnt much good without pics of how to install the thing ;)
    Your idea sounds like a great starting point.
  4. loony888 Husqvarna
    australia
    400 CR0SS
    Ducati's
  5. Sandgroper Husqvarna
    Dubai
    Is there any pic for the braket mount on the carb?
  6. loony888 Husqvarna
    australia
    400 CR0SS
    Ducati's
    mine didn't use a bracket to mount on the carb, the plunger screws in on the same thread the red button plunger assembly uses and the 90 degree bend in the cable just sits there, the rest of the cable is secured to the wiring loom where it runs against the frame towards the headstock, then turns behind the top triple clamp and mounts to the back of the magura perch.
    paul.
  7. Poopy Husqvarna
    Kamloops, BC
    WB165
    Is it actually a KTM part that you use on the carb then?
  8. Sandgroper Husqvarna
    Dubai
    Think I havre the jist of it but will need to look at a ktm to be sure, thanks
  9. 5valves Husqvarna
    Gardner Kansas
    Dr D has a kit also. They dont have the Husky listed but one of the others should be able to be adapted.
    I have installed one on my yz the older models didnt come with one.
  10. Sandgroper Husqvarna
    Dubai
    Yeah, the handle bar lever is the easy part, I just cant picture the pivot braket on the carb.
  11. HuskyMax Husqvarna
    WV
    What year bike do you have? There shouldnt be any pivot bracket on the carb. When you unscrew the red hot start there will be a plunger on the end of it. The new cable will have the same thing but a metal elbow and a threaded nut that screws right on.
  12. HuskyMax Husqvarna
    WV
  13. Sandgroper Husqvarna
    Dubai
  14. andyman Husqvarna
  15. Coffee CH Owner
  16. andyman Husqvarna
    Call it what you may... but it's cheaper than a cable and lever, and it keeps me from fiddling with the knob on the carb. :cheers:
