Hour meter set up on TC 449
Discussion in 'General (Main)' started by PawPaw, Jul 30, 2014.
  1. PawPaw Husqvarna
    2013 TC 449
    Honda Crf450R + old CB750
    I am a new "old" guy here with a lot of experience working on all types of bikes, but this one is a bit different.
    I want to install an hour meter on it, but have run into issues doing so. I have read the other post on this site and have researched the net for a solution, have tried some, but still I can't seem to get it to work. I have tried the wrapping the wire around the plug boot below the weather seal with 5 wraps and that did not work. I have tried some other things that did not work either.
    Does anyone have a solution?
    Will it maybe need to be hard wired instead?
    If so, where?
    The fuel pump?
    Thank for your help!
    Paw Paw
  2. PawPaw Husqvarna
    2013 TC 449
    I solved the problem with a vibration hour meter. It seems to work ok.
    Paw Paw
  3. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    Motominder meters will work off any electrical signal.
    I hooked mine to the fuel pump relay output wire.
    Meter counts whenever the pump is running.
