250-500cc How do I remove ignition 08 WR 250
Discussion in '2 Stroke' started by fire1998, Feb 11, 2009.
  1. fire1998 Husqvarna
    Cheyenne, WY
    Trying to fix the threads on my crankshaft from a mishap with a flywheel. Got the flywheel off. How do you remove the ignition? Do I need a puller?
    Thanks
  2. Norman Foley Husqvarna
    Should be 3 screws that hold it in place. Make sure you index the position with a scratch mark or sharpie, so you get timing correct on re-install.
