How do you keep your shrouds together?
Discussion in 'General (Main)' started by racemx904, Jan 14, 2011.
  1. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    I have raced and rode Husky 125's sice 2002....never had a problem witht he shrouds coming apart so often...I might have one here and there....but on this TE250 I have both flopped out and have broke the mounting points to the tank a few times too...not sure if it is cause the shrouds are flexed more or what...
    What solutions have you guys used?
    I was thinking a small bolt near the front of the shroud to bolt them together...
    or some sort of trim up the front to keep branches and debris from splitting the two open...
    I have heaard of zip ties from the radiator to the shroud....
    aahhhh
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    Here is what I did on my 06 TE450, I used threaded inserts with the aluminum hex head screws, sourced from road race/street fairing guys/companies. They worked very well and there was a color choice of anodized fasteners.
  3. robertaccio Husqvarna
    San Diego, Ca
    sorry 2 of same here from inside
  4. racemx904 Husqvarna
    owenton, ky
    that is what I was thinking....I have some from a street fighter project a few years ago...thats roberto
  5. robertaccio Husqvarna
    San Diego, Ca
    On my 08 I just put pieces gorilla tape at the split between the upper and lower gap to keep stuff from getting in between the shrouds and popping out the tab. Its not very noticable Its black ultra strong "duct" tape
  6. ThunderPaw Husqvarna
    Humboldt county
    This may not meet most peoples ascetic requirements but it has worked for me. I installed radiator braces which created a fitment problem with the stock shrouds (I also have an IMS 3-gallon tank). I made my own shrouds by cutting a heavy duty mud flap to shape. The whole affair
    sticks out less and has never been damaged. The stock shroud does transfer blows to the radiator. No cooling issues have resulted, it might even ram more air in there.
  7. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Is that a ProMotoBillet kickstand or.......? I see you've got it leaning against the guardrail. Nice idea for you lower shrouds.
  8. dfeckel Husqvarna
    Medford, NJ
    I'm amazed that none of the plastics companies have made a one piece upper/lower fairing option yet.
  9. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    That works! :thumbsup:
  10. racemx904 Husqvarna
    owenton, ky
    I like it....
    I really like the bungee cord stablizer too...
  11. oldskool63 Husqvarna
    tennessee
    My rad shroud upper tabs wouldn't stay "tucked" and only street riding. I cut 4 pieces of aluminum 1" long X 1/2" wide X 1/8" thick, drilled & tapped 6mm holes on 3/4" centers. Discarded the oem retaining clips. This set-up moved my shrouds 3/4" higher (where they should have been to begin with). It looks like Husky is doing a better job with plastic fitment on the newer models.:applause:
  12. racemx904 Husqvarna
    owenton, ky
    I wish they would just make it one solid piece...even one color...
  13. racemx904 Husqvarna
    owenton, ky
    still considering doing the mud flap deal....
  14. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    I am too, it's brilliant and probably very durable without transferring impact damage to the rads. I recently destroyed my right "conveyor" somehow, and although it's only $12 to replace, I feel the heavy rubber shown above would work and hold up much better when I lose talent:busted: Another reason for me is that the conveyors on both sides don't fit under the upper shrouds with the IMS tank. Not a huge deal for me because the tank is otherwise awesome but, still a contributing factor to go with the mudflap conversion!
  15. racemx904 Husqvarna
    owenton, ky
    Just gotg to find some thick rubber now...
  16. ThunderPaw Husqvarna
    Humboldt county
    Thanks. They don't have to be super heavy duty (personal choice). i used a thicker pair of Kragen cheapies. They are reinforced with fiberglass. Someone might come up with a better source material, but flaps are meant to be tough and are readilly available in the mean time.
    Ioneater, that is a Promoto Billit with a bit of a bastardization story behind it.
  17. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Well, thanks to Thunderpaw's idea for lower shrouds I got the itch to try the mudflap style myself tonight. $22 for a set of Plasticolor fiber reinforced flaps at O'Reilly's. I made a quick pattern from thick paper and proceeded to chop away. Mine won't work as well for airflow due to a different style of tank and using stock upper shrouds that stick WAY out now. I'm thinking about making some sort of quick disconnect lightweight cable retention straps to go from near the tip of the upper shrouds to somewhere near top of rad braces or something.... Those shrouds are easy prey for the trail if I don't do something. Here are a few pics...
  18. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Here's what happens when the stock conveyors take a hit from the side using BPD braces. Note the conveyors are bolted directly to the radiators and transfer any impact to them via those small mounting tabs on the rads.
    That was my main reason to go with flaps, allows the braces to provide the protection they were designed for.
  19. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    I haven't had too many issues with this... I have used gorilla tape- that's about it: decreases Twig'N'Leaf collection. I once slammed into a tree pretty squarely with a radiator/ fork tube/ headlight... killed the blinkers and tore the upper shroud a bit, lower shroud came partially off- simply rebolted back on. Expected destruction... it happens. I have hit lots of various trees- that was the only time any noticable damage occurred that I recall[IMG]
    I have OFG braces.
  20. TE 250 Girl Husqvarna
    Roslyn, Wa
    ioneater; I see in your picture that some of the little "tabs" in your radiator are bent or squished. I have this damage too, only a little more so. Is this really bad? My bike runs fine and doesnt get hot, so does that mean it will be fine?
