how long do you get from your wheel bearings ?
Discussion in '4 Stroke' started by rabskyline, Dec 22, 2009.
  1. rabskyline Husqvarna
    Sunshine Coast,Queenslander !!
    2014 te250r
    Yer maw !
    there is a bit of play in my fronts after only 600klms(360 miles ish ? ) max ! i wouldnt consider this to be good from the main dealer supplied and fitted when i bought it but as they are cheap, i'll replace them anyway... what do you get from yours on forest/trail riding only ?
  2. ray_ray Mini-Sponsor
    The Philippines
    On my 02 CR250 I get ~3 years worth of riding at least on single track on the fronts...No sure of the miles but we only ride 4-5 months of the year due to bad weather and this is usually 1 day a week...This has to be several times more miles than you stated here...Probably 25-40 miles per ride only but some of the stuff we ride in is ~gnarly so the wheels take a beating...
  3. Slowpoke Husqvarna
    Southern Ontario
    Still on the original front and rears. Over 300 hrs & ~7300kms of all types of riding, incl. many thousands of water holes, mud holes, fire roads, hwys, technical singletrack etc.
  4. bajahusky Husqvarna
    jackson, wy.
    have you checked them? i checked both at about 500 miles and the rear was toast and the front was close to toast.
  5. razornpc Husqvarna
    iowa
    mine lasted about 6-7 months. not sure how many miles. i cleaned and repacked them in the spring and this fall they needed replaced.
    well 1 needed replaced and the other one still felt fine so i kept it for a spare.
  6. tadgh Husqvarna
    thats pretty amazing longevity some of you guys get. i reckon i replace mine at least every 25 hours. especially the rears.
    i only race the bike if that makes a difference and because i use mousses in the tires i dont care about banging through rocks and roots. also the terrain is usually always wet or muddy so it doesnt help.
    bearing cost doesnt seem to make any difference dear or expensive they all seem to last the same.
  7. ray_ray Mini-Sponsor
    The Philippines
    25 hours? Do they have slack or wobble in them? Or are you just repalcing to replace? I'm not sure about the different bearings either. My OEM bearing for my 02 Husky lasted quite a while...I have the all-balls or something brand in them now...
    Maybe I can be UR bearing dealer? ;) We'll set you up and a weekly schedule :) as we don't you to loose any thing from any friction that might be building up after the wheel as spun more that a dozen times...
  8. dirt-dude Husqvarna
    Pa.
    You can pick the plastic seals off with a razor blade and clean
    the grease out of the bearing with contact cleaner, and repack
    with synthetic or water proof grease and reinstall the plastic seals
    for longevity in wet riding conditions.
  9. rabskyline Husqvarna
    2014 te250r
    Yer maw !
    i pre packed the rears but the dealer said he done mine before i got it but i never checked them.. anyway, will do them over the holibags !
  10. Slowpoke Husqvarna
    Southern Ontario
    Yep, many times & everything is still good. I'm a bit fussy when it comes to maintaining my bike and making sure it's always ready to go.
  11. tadgh Husqvarna
    haha well in the type of terrain thats the how long they last. i replace them just as they start to be able to be rocked
