125-200cc How much gear oil for 2013 CR 125
Discussion in '2 Stroke' started by Sturmjaeger226, Feb 21, 2013.
  1. Sturmjaeger226 Husqvarna
    Colorado Springs, CO
    '07 WR144, Soon '12 CR144
    '09 YZ250
    I have a 13 CR 125/144, and no where in the quick manual does it say how much transmission oil to put in. I recall it being a good amount, maybe over 800ml. Just wondering if anyone knows for sure.
  2. huskybear Husqvarna
    B.C. Canada
    Should be the same as my wr-800ml,level should be in the middle of the "window" with bike up-right and level,engine warm:cheers:
    454x likes this.
  3. dirt addict Husqvarna
    Southern Kalifornia
    2014 cr125
    Fyi I just read thru the 2013 manual and it said .18 us gal = .68 liters , which I translate into .7 L .
    Does anyone have anything different?
  4. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    Having a older model the manual I have says this
    there is a little screw / bolt with a copper washer (near the water pump) that have to be unscrewed
    keep the bike level and fill her up with oil until the oil bleeds from this hole where the screw is located
    put the screw back and your fine
    Robert-Jan
  5. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  6. dirt addict Husqvarna
    Southern Kalifornia
    2014 cr125
    Ok Tinken I'll go close to that. More oil the better. I hear you guys have some good suspension settings for the little cr. We have some common friends who told me to take my suspension down to you....
  7. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
