How much oil? - aftermarket oil pump and filter?
Discussion in 'Older Single cams' started by Sund, Mar 27, 2015.
  1. Sund Husqvarna
    Denmark
    TC610 1990 frame. Approx 1997 engine
    BMW R60/6 1976, Sold. YZF 250 Sold.
    I have a 95-98 TC engine which doesn't come with an oil pump, or oil filter.
    Mine has both installed now. How much oil should I give it, when changing the oil and filter?
    How often would you change the oil? (I only ride on the road.)
    What happen if one gives an engine like that too much oil, does it just have an "overflow security" somewhere? - or will bad stuff happen?
    Thanks in advance! :-)
  2. DaveM Husqvarna
    Adelaide, Australia
    2001 TE 570
    Motorised Bicycle
    Hi,
    Here is manual for your bike, stock oil quantity will be there.
    http://husqvarnaoutlet.com/repair_manuals
    I change my oil after every day long ride.
    Oil is relatively cheap in comparison to engine parts.
    I use Belray Thumper Racing 15w/50, Synthetic Ester Blend.
    It is very easy to get caught up in the advertising hype and pay too much for oil.
    Too much oil you could blow seals!
    Cheers, Dave.
  3. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    If you have an after market oil pump and filter the suppliers should be able to tell you how much oil. Who supplied the pump, could we have some photos please?
    MEGA_MAX and DaveM like this.
  4. Andy clark Husqvarna
    1997 te610
    Suzuki gsxr1000 k6 honda c90
    Any pics of your oil pump set up? How is it driven dose it pump oil to the head?
  5. Sund Husqvarna
    Denmark
    I have no idea which model og brand it is. Last owner said nothing about it.
    Iam trying to replace the hoses as one of them were cracked.
    MEGA_MAX likes this.
  6. Sund Husqvarna
    Denmark
    Last one is from the top of the Oil filter.
    So.. How much oil would you guys think.. I should run with? :-)
  7. stormer254 Husqvarna
    England
    Yes!
    I would work out the amount held by the add on bits, filter , pipe work pump etc. Then add it to normal amount for a start and run it for a bit. stop it and check the oil level. Adjust to suit!
  8. rancher1 Husqvarna
    WA
    Wow someone went to a lot of thinking on that. I would probably just get the newer cases that have the oil pump in them already.
    DaveM likes this.
  9. MEGA_MAX Husqvarna
    1993 Husky TE610
    2008 Suzuki DR650
    This sounds like the best route. Interesting to see how the P/O did it, but how could you possibly leave out the retro-fitment of an oil pump and filter as a selling point? lol
  10. Sund Husqvarna
    Denmark
    It also has a hydraulic clutch.
    I dont know why he did not say anything about that. Dont think he knew that much about the bike. Not the last owner who did the stuff. And I diden't ask because I was (still am) a newbie :)
