125-200cc How much trans oil in a 125?
Discussion in '2 Stroke' started by Parh 474, Nov 8, 2014.
  1. Parh 474 Husqvarna
    Newbury Park, CA
    '73 Cr125, '06 Cr125/144
    Ossa, Bultaco, Puch, Maico, AJS, Yam
    Manual says 10,8 (no units) or .7 Imp qt. Which could be 10800cc or 795cc.
    I hate Italian manuals. At least the Japanese know they don't speak English. And the 4 languages side by side is the biggest PITA this side of the Rubicon.
    woodsrider likes this.
  2. Parh 474 Husqvarna
    Newbury Park, CA
    Also what weight oil? AGIP City 4T, as stated in the manual, isn't very meaningful to me.
  3. Parh 474 Husqvarna
    Newbury Park, CA
    Oh I get it now- L0.8 not 10,8. 800cc. jeez.
  4. Norman Foley Husqvarna
    I was about to tell you that. I always ran 10-40, in my '02 and '09 125's.
  5. dirt-dude Husqvarna
    Pa.
    I put 850cc lean it to the left, and then let it set level on the stand. Remove the inspection plug and let it run out till it slows to a drip, put the plug back in and you're good to go. I usually use belray gear saver its 70 or 80 wt, I've also used rotella engine oil non synthetic 10/40 just change it more often..
  6. Parh 474 Husqvarna
    Newbury Park, CA
    I had some Maxima MTL 75 and 80 half bottles, so used that. Suppose it'll be fine.
  7. Parh 474 Husqvarna
    Newbury Park, CA
    Thanks for your responses.
  8. Parh 474 Husqvarna
    Newbury Park, CA
    They should have kept a couple Swedes to write their manuals. They made sense and the guys in their lab coats and clogs were cool.
  9. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    dont forget the one piece mechanic outfits
    Parh 474 likes this.
