How safe is this?
Discussion in '610/630' started by notoriouz, Jun 12, 2013.
  1. notoriouz Husqvarna
    2011 SMS 630
    2009 Ninja 650r
    How safe do you think it is to use this rear sprocket for about a week until my new sprocket and bolts/nuts arrive?
    I don't think I can stay off the bike any longer, if I just torque the remaining 5 bolts and take it easy, will the sprocket survive?
  2. Gav Husqvarna
    West Sussex, United Kingdom
    SM610
    GSXR 600 SRAD:Sold ZXR 400 H2:Sold
    I'd probably ride it, others might not.
    I wouldn't go pulling any wheelies mind you.
    notoriouz and JonXX like this.
  3. RDTCU Husqvarna
    '11 630SMS
    Check the others and ride it. Don't be crazy for the next week.
  4. Motosportz CH Sponsor
    No problem at all. Run it. Replace the bolt and any others that might be damaged of course.
  5. notoriouz Husqvarna
    2011 SMS 630
    2009 Ninja 650r
    Thanks for the input guys, it helps put my mind at ease. I just torqued the remaining 5 bolts and went for a 10 minute ride, checked them half way through and again at the end, they all seem to be staying tight for now. I'll just be sure to check them before and during my rides for the next week or so.
    I just ordered a 38t rear sprocket and 6 replacement nuts and bolts from Hall's. Just need to wait for him to order the sprocket in before he can have it shipped out!
  6. 1lunger Husqvarna
    Bloomfield CT
    38?? Or 48? That a small one if its a 38!
  7. RDTCU Husqvarna
    '11 630SMS
    Factory SMS rear is 38. 17" wheels, remember, and we don't have the taller 5th and 6th of the TE. Mine tachs out around 110mph with stock gearing.
    48T on a SMS would be stunt gearing.
  8. 1lunger Husqvarna
    Bloomfield CT
    My bad, should have looked at the profile.
  9. mnb Husqvarna
    San Jose, California
    2011 TE310 . . . . 2003 TE610e
    interesting, stock gearing for the '03 SM was 15/45, same as the TE.
  10. RDTCU Husqvarna
    '11 630SMS
    610's had the same internal gearing between them, while the 630's have a different 5th and 6th ratio between the versions, both of which are lower than the 610 internal gearing. The TE has a taller 5th and 6th than the SMS.
  11. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    I would run it. Cam.
    notoriouz likes this.
  12. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    I'd run it. What's the worst that could happen? The sprocket breaks loose, the chain wraps around the axle, locks up the rear, and you do multiple endos down the trail. I wear full Leatt gear and read my Bible every morning. No worries, mate.
  13. Philthy Husqvarna
    Mackay, Australia
    Yammy WR250f
    I'd ride to the hardware store and look for a similar temporary bolt to make do until reinforcements arrive. And +1 on the no wheelies.
