250-500cc How to adjust float level Mikuni TMX 38?
Discussion in '2 Stroke' started by Murda_man, Jul 5, 2012.
  1. Murda_man Husqvarna
    WR300
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    My float was set too high from the factory (as well as having the wrong jets and slide in it), so much so that the bike dripped fuel when it was not running if the gas tap was on. I adjusted the float level so that the floats were level and square with the edge of the carb body without the float needle spring getting compressed.
  3. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    huskybear likes this.
  4. kiethy Husqvarna
    Australia
    18-22 is for older tmx, it's the only carb i've seen that adjusting to level is no where near correct. I have a pwk and with the float set right on mikuni it's way more responsive in bottom to mid.
  5. john01 Husqvarna
    Powhatan VA
    Thanks for re-uping the pics and carb info :cheers:. I just set the float on my 08 CR 165 and she runs a LOT better and no more gas dripping from being on the side stand!
  6. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    John what height did you use on older carb?
  7. john01 Husqvarna
    Powhatan VA
