How to flush/change coolant?
Discussion in 'TR650' started by DeLewis, Feb 26, 2015.
  1. DeLewis Husqvarna
    Melbourne, Australia
    I have searched high and low on here and elsewhere for a 'how to' guide on flushing the coolant and found nothing specific for the TR650. Having consulted the resources for the BMW 650, I have done the following:
    1. Removed the radiator cap.
    2. Removed the bolt from below the water pump which drained about half a litre of coolant.
    3. Removed the water hose from the cyclinder head which feeds into the lower part of the radiator. Perhaps another 100mls of coolant drained out.
    Clearly there is a lot more coolant to drain as the manual States that the cooling system requires just over a litre of coolant. One of the guides I consulted for the BMW GS650 indicated that to get a full drain the thermostat has to be removed from the radiator. Could this be the case for our radiators too? If so, how is it removed?
    Thanks for any advice!
    UPDATE
    I managed to dig up an old post which covers off on the factory manual instructions. And when I actually measured the coolant drained from the bike it was almost exactly 1 litre.
  2. Link Husqvarna
    Modesto, CA
    TR650
    Aprilia, Honda, HD
  3. AzOzRider Husqvarna
    Brisbane
    HD, BMW, Suzuki, Kawi
