How to Re-Torque Crankshaft Nuts
Discussion in 'Vintage/Left Kickers' started by ssaulnier, Oct 15, 2010.
  1. ssaulnier Husqvarna
    San Antonio, TX
    I see where the Husky tech manual suggests re-torquing the nut holding the flywheel a couple times after so much run time. What is the process? Do you loosen the nut and then torque back to spec? That is the only way I have heard to torque a nut or bolt. What good does that do? Does this process just seat the flywheel deeper on the crankshaft?
    Note that I am not poo-pooing the need for re-torquing. I can see evidence on this bike where the nut got loose and the flywheel trashed the ignition stator. The stator mysterously went missing 25 years ago but you can see some scars on the flywheel.
  2. tommie d Husqvarna
    Kansas
    Twenty one and counting
    Two Honda's
    I never loosen the nut unless i'm going to pull the flywheel. To check it, I just use my torque wrench to make sure it clicks over at the 51ft lbs setting.
  3. fran...k. Husqvarna
    eastern ct
    I don't know if it is true or not but have heard some of the effects on that taper on the ignition side attributed to electrolisis. What does the manual say? something like re torque after 2 minutes then half an hour then two hours something kind of like that. They also tell you to use grinding paste like for seating valves if you are switching to a different one. I think it kind of creeps in on the taper that is why but doubt they do that for a new bike.
  4. ssaulnier Husqvarna
    San Antonio, TX
    Thanks guys. I did lap mine with valve grinding paste when I replaced the ignition stator and flywheel. Then I torqued it to spec (dont recall the number - I looked it up in the manual).
