250-500cc How to remove swing arm?
Discussion in '2 Stroke' started by 99WR250, Apr 1, 2013.
  1. 99WR250 Husqvarna
    1999 WR250
    Yamaha TW200
    Trying to remove the swing arm on my 1999 WR250. I'm removing the swing arm in order to work on getting a stuck chain adjuster bolt out...long story, another thread. Anyway...I'm down to just trying to get the swing arm axle out but it won't budge. Shouldn't this just pound through from the left hand side of the bike...I've tried heat and hammer blows to no luck.
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    you got bike on a stand i assume(stupid question but...)? probably never been out, seized/rusted bushes in there. maybe lie bike on its side & flood with wd40 in & around hole on both sides. i took mine out the other day, undo nut till few threads left on bolt & tap(didnt pound :)) out. maybe get some one to keep moving swingarm up & down as you tap/pound it out. mite become a sacrificial swingarm bolt if worse comes to worse. ps my chain adjuster bolt snapped too, sucks hard
  3. 99WR250 Husqvarna
    1999 WR250
    Yamaha TW200
    The weird thing is the swing arm moves freely up and down. It appears as though the previous owner was at least good about greasing the zerk, but most likely that swing arm axle has been in there since day one back in 1999. I'm worried that it's corroded to where it goes through the motor case. Does the swing arm need to be in a certain position (up or down) to get the axle out? Also should I pull the shock?
    On a side the my manual goes into detail on how to do a complete engine rebuild but has no info on how to take the swing arm off. Is there another source of info I could consult (shop/haynes/clymers) ?
  4. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    i have my shock out to get serviced & grease/replace bearings. give you more room to play with. undo tie rod & bottom shock bolt at least but id take the lot apart to check & repack/replace all the bearings/seals/bushes etc & service shock(itd be due!). mines a 2010 wr300 but id reckon there the same or very similar cases. theres only 2 bushes in the cases the bolt goes through that it could jam in & they dont come out easily(but no real need to remove in general)! unless the bolt has rusted/corroded/swelled in between them bushes then you might be in strife! wheres the zerk? is it to grease swingarm bearings? mine dont have one. keep trying!
  5. 99WR250 Husqvarna
    1999 WR250
    Yamaha TW200
    Zerks are on each side of the swing arm next to the bearings. I'll take some pics tonight
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    yeh sweet mate id be interested to see them, sound like theyd be the go, my swingarm bearings end up rusted out before a year!
  7. 99WR250 Husqvarna
    1999 WR250
    Yamaha TW200
    Yeah... The swing arm moves up and down fine and the swing arm bearings feel fine. I don't see any real reason that I would ever need to replace the swing arm bearings as long as I keep them greased. Maybe if my swing arm needed replacement, but at that point is buy a new bike. So in theory its ok if the swingarm axle is stuck in the engine case. The only reason im trying to get the swing arm off is so I can get a better angle at drilling out the chain adjuster bolts.
  8. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    No.
    Try heating where it goes through the cases with a torch. If that doesn't work spray some of your preferred brand of penetrating oil/spooger in the joint between the swingarm and cases and then lay the bike on it's side so it will soak down towards the engine for a day and then repeat on the other side. Then try to drive it out.
    You can get fairly aggressive with the hammer as long as you find something that fits inside the swingarm to protect it. I think I used a socket extension.
  9. 99WR250 Husqvarna
    1999 WR250
    Yamaha TW200
    It's ok to heat the cases?
  10. Motosportz CH Sponsor
    I bought a 04 CR125 and had the same issue. Was nearly impossible to remove. I have seen it all and worked on piles of bikes and got so frustrated and almost parted that sucker out. I ended up hack sawing it half the way out before giving up. Luck buddy Tim said he would take it from there and spend many a frustrating hours hacking it the rest of the way out. (thanks again Tim Troffer) Is not EZ, cases got a little hacked, and obviously had to buy and swingarm pivot bolt. Mine rotated fine to but knew the bearings were way toast. Hope you have better luck, some are so frozen cutting them out is the only way.
    Once you get it fixed take it out once a year and clean it up / reinstall.
  11. bdl507 Husqvarna
    New Hampshire
    99 wr360
    rd350 dr650 tt500 pe250 hondas lots
    Air hammer very carefully (I know its hard to have the two words in the same sentence)
  12. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Use PB Blaster, it's the best penetrating spray I've found.
  13. 99WR250 Husqvarna
    1999 WR250
    Yamaha TW200
    I'm at the point where I might just say F it and just leave it in. As far as I can tell and feel, the swing arm bearings are ok, and as mentioned above I was only trying to get the swing arm off to work in the chain adjuster bolts. Guess ill just suck it up and drill out the chain adjuster bolts with the swing arm on the bike.
  14. colemanapp Husqvarna
    St. Louis, MO
    I've been right where you're at. I ended up using some older style 'pull' adjusters. I used a set on 93 Husky with same problem . You'd have to do a little cutting of the 'wings' of the pull to get it to fit in the swingarm space, drill out the hole to accept the larger axle you may have, and trim down your existing wheel spacer if the axles not long enough after you add these.
    Here's what I have
    they came off an 88 Husky
    ohmygewd likes this.
  15. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Sooner or later you are going to have to get it out of there to either remove the swingarm or the engine. I'd spray it with PB Blaster often so when that someday comes it might help you remove it.
  16. NephronRacing Husqvarna
    Minneapolis, MN
    2002 CR250
    '98 Ducati 748, '69 Honda CB350 Cafe
    I tried everything on the 2002 that I'm parting out...PB Blaster, WD40, Heat, Tapping, Pounding, Air Hammer. Finally got it out but the axle was toast. Probably spent 24 actual hours trying to get that thing out over the period of a few weeks.
    Motosportz likes this.
  17. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    You could also try undoing all the engine mount bolts and try to rotate the engine up to break it free
  18. Motosportz CH Sponsor
    I did both those things, and heat, and everything else and no dice, was locked in tight. Had to cut it out. Not the first time that has had to be the case ether. Tim had to cut one out too on another bike.
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    is it a hollow job like 360? can you tap a thread in the rhd side big washer over frame cut out and screw the bolt in to the swing arm bolt to get it out, looks like your in for a hell of a job tho 99wr250 good luck
  20. Motosportz CH Sponsor
    Not a bad idea. Yes they are all hollow. Then you could use a huge socket and pull it out like a puller. Once you got it to move a half inch or so the rest should be gravy.
