How To Use The Ibeat?
Discussion in 'EFI/carb' started by little squirt, Feb 18, 2012.
  1. little squirt Husqvarna
    Honolulu, HI
    bought the Ibeat from semco here, sponsored link. but no real instructions on how to navigate it when hook up...i reset the TPS and played around a little but is there a factory manual or a guide to how to use this? I couldnt find the CO readings or temp sensor values while hooked up or how to set/reset the CO settings....any manual or help would be great. Thanks!!
  2. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    There should be a folder called "Manual" on your ibeat installation CD. In that folder you should find iDT_OperationManual-English(2.00).pdf or similar.
    The temperature should be displayed on the main dashboard window.
    There is also a button for CO adjustment. Alternatively, you can select "CO Adjustment" from the service pull-down menu.
  3. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    Yes the CO, TPS, FB adjustments are on the top row on the main screen. Hover your mouse over the icons and they will give you a small description of what they are. BTW, this is all on what is called the "dashboard" or what I call the main screen.
