Husaberg Foot Pegs Fit The 630, Nice And Wide
Discussion in '610/630' started by sethro, Aug 19, 2011.
  1. sethro Husqvarna
    flagstaff AZ
    Hello all
    Just wanted to share with the group. I had a set of foot pegs laying around off my 2010 FE570 and wondered if they would fit on the 630. The 630 foot pegs are just to narrow to stand on for very long.
    Anyway all you got to do is gring them down a little bid as they are a touch too wide to fit in the bracket. They look great and are heck of allot wider than the stockers.
    BTW Husaberg foot pegs are the same as all the late model KTM bikes
    Huge improvement and work awesome
    Thanks
    Sethro
  2. Fast1 Husqvarna
    Minneapolis, MN
    so do the TE510 footpegs without any modifications at all..
    jtemple likes this.
  3. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    Reeeeallllyyy...
    Good info! I might have to pick up a set of 510 pegs.
  4. Fast1 Husqvarna
    Minneapolis, MN
    at least I can tell you that the Roc-Stompa pegs did, however I would assume other 510 pegs would also fit fine without any necessary modifications.
    Something I forgot is that the tab on the right peg mount requires a reduction in height to not interfere with folding. This is required regardless of the aftermarket pegs installed from what I've been told. You just need to cut it to the height of the tab on the left side.
    shown before cutting
  5. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I just ordered up a pair of 510 pegs.
    EDIT: Scratch that. I was under the impression that the above pictured black pegs were 510 pegs. I guess not!
  6. Fast1 Husqvarna
    Minneapolis, MN
    If you are referring to my black Roc Stompa pegs.. yes they are 510 pegs. I took them off my 510 before selling it and bolted them right on the 630 without any modifications to the pegs.
  7. LawnDartMike Husqvarna
    Salem, OR USA
    I'm pretty sure about any Husky (modern) foot peg will fit. I just swapped in the stock pegs off my '09 WR125. Perfect fit. I run Pivot Pegz on the WR and am tempted to swap them to the SM630 when I'm not out playing in the dirt.
  8. CJBROWN Husqvarna
    Orange County, CA
    '15 R1200GS
    Tell us about your 'berg - did you keep it or replace it with the 630, and why.
  9. Motosportz CH Sponsor
    any standard footpeg should work. Might have to grind some of the post down to slide it in the opening but should work.
  10. Fast1 Husqvarna
    Minneapolis, MN
    here are the photos of the pegs on my TE510 before I sold it and installed them on my 630
  11. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I installed the 510 footpegs tonight. The right one required a tiny bit of grinding to make it fit. Just a hair off of one side of the peg.
    When I went to install the left, it fit right in. It kind of makes me wonder if I should have spread the mount apart a little on the right side instead of grinding the peg. Oh well. :)
    They have three rows of teeth instead of two. They're also wider (front to back). I think they'll do just fine for me.
