Husky Club newsletters?
Discussion in 'Vintage/Left Kickers' started by Houredout401, Dec 23, 2021.
  1. Houredout401 Husqvarna
    New England
    '77 CR250 '78WR250
    '76MR250 '83IT250 '84 IT490 '69CT70
    So Im back after hiatus working to complete a 1983 WR430. Looking for wiring diagram to recreate the lightning harness and say a post about that being in #25. But when I click on that link, it goes to go daddy.com. Are these no longer available?
  2. Vinskord Husqvarna
    400 CR
    The links to the Newsletters no longer work. Someone may be able to point you in the right direction for the complete Newsletter, but in the interim here is the info that you are looking for.
    2premo likes this.
  3. Houredout401 Husqvarna
    New England
    '77 CR250 '78WR250
    Excellent thanks. While you are here, did the 83 WRs have a dust cap/seal on the top steering head bearing? Diagram only shows the lower bearing set up.
  4. Vinskord Husqvarna
    400 CR
    The late 70's and 80's bikes are beyond my knowledge - I'm sure someone will provide a good answer. My experience though is that the Husqvarna parts diagrams are pretty accurate - if the part is not graphically shown, the parts list will address the assembly - either by quantity, size, and even sometimes the manufacturer.
  5. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    The steering head bearings have the seal installed on the bearing itself. No need to add an additional seal.
    Houredout401 likes this.
  6. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    15 13 070 01 is the part number and looks like a seal on the bearing, pasts fiche shows 2, so assume the top bearing seal takes care of that
  7. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    http://www.3medesign.com/husky-club-newsletters.html
  8. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    If not i'm pretty sure i have most of them in PDF format, somewhere
