Hi there! After finding alot of threads with people having with their clutches i thought is should share this. My clutch went spongy (on the side of a real steep hill) and after going to my mate and local husky dealer i changed the fluid to brake fluid. 2000kms later and havn't had any more dramas! Enjoy
be carefull, It has been established that the seals in a Magura Clutch will degrade from the use of brake fluid. This came about when ktm swiched from magura to brembo (which uses brake fluid) many guys started mixxing it up and ended up with problems.... Maybe you will be lucky... But I would never put brake fluid in my Magura. You can use- ATF tranny fluid, fork oil, mineral oil, Magura Blood.
The Rekluse Lefthand Brake kit comes with a Magura MC. It looks exactly like the clutch MC, only black not polished. I wonder what the diff is or if you can just swap out the seals.
