Husky Grease
Discussion in '4 Stroke' started by danbartol, Nov 28, 2009.
  1. danbartol Husqvarna
    Colorado
    I'll soon be picking up a 2010 Te510 and was wondering if Husky applied a bit more grease to it's bearings from the factory than the typical q-tip swab of vaseline the Japanese manufacureres do?
    Thanks, Dan
  2. Coffee CH Owner
    Who knows how well the 2010 bikes will be greased now that BMW has fully integrated. My 2006 was lithium based and was greased 'ok', much better than some other brands. My understanding is that there are issues to consider like shipping a bike with grease dripping out of it, or weight of tested bikes... at least those were the latest theories on factory grease.
    Regardless, I remove lithium based greased and use Bell Ray, it tends to stay where I put it and not leak out in warm weather.
  3. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    I can't figure out why...but this is what I've been told also.
    Taking your new bike apart before it's initial ride has always been the norm. Never tell what you'll find. Little grease, no grease, pinch seal, etc.
  4. wulf22 Husqvarna
    Utica, NY
    My 09 TXC250 was greased better than any other new bike I had. That said it was still a under greased for me. I cleaned the white stuff out and lubed up the linkage with Bel-Ray waterproof grease with anti-seize mixed in.
  5. ghte Husqvarna
    Bright, Victoria Australia
    Yep I think the level of factory greasing is reasonably OK. I would prefer to do say 500 ks (300 miles) then strip out and repack the factory stuff in the swing arm, linkage and head stem. I would also lift the cover of the wheel bearings, wipe and clean as much as possible and repack. Also put as much grease and you can on top of the bearing behind the outer seal, on the spacer and axels. When its time to replace bearings look at Seahorse's thread on repacking the bearings before you pop them in.
  6. danbartol Husqvarna
    Colorado
    Good info. Thanks!
