125-200cc Husky TE 410 rear wheel fitment to WR 125
Discussion in '2 Stroke' started by mr.freezer, Dec 28, 2016.
  1. mr.freezer Husqvarna
    SM 125 2000
    Ducati Monster 620 ie, Suzuki RM 125
    Guys does TE 410 and WR 125 have same wheels?? I need new rear wheel for my WR 125 and I can buy just one from TE 410
  2. rancher1 Husqvarna
    WA
    What year of 410 and 125 ?
  3. mr.freezer Husqvarna
    SM 125 2000
    TE 410 1998 and WR 125 2000
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    No the 4 stroke hubs are 5mm wider, also I think your 125 will have smaller Axel's do you would need spacers as well.
  5. mr.freezer Husqvarna
    SM 125 2000
    5mm in not much... 5mm off from spacer??... and I think axels are the same
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    5mm on the hub! So the sprocket won't align either get it machined down to correct size and then make a reducing set of spacers for the axel to fit in.
  7. rancher1 Husqvarna
    WA
    I was asking the years of the bikes because some years they would be the same.
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yeah still think that combo won't work.
  9. rancher1 Husqvarna
    WA
    It will depend on the year. In 2009 the 125s switched to the four stroke hub.
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    It's a 00 125 an a 98 te410 so no the hub won't fit.
    Just saying.
    What's actually wing with the 125 wheel? Can't you get it re built?
  11. mr.freezer Husqvarna
    SM 125 2000
    I have just SM wheels and now want to swap it for offroad...
  12. rancher1 Husqvarna
    WA
    A 2000 TE 410 wheel would fit, same hub.
  13. mr.freezer Husqvarna
    SM 125 2000
    Guys.. and what about TE 250 2004 rear wheel?? is the hub the same as WR 125 2000 hub??
  14. SmokeyExpress Husqvarna
    Canberra Australia
    2014 WR300, 1996 WR360,2013 WR125
    Solution!
    1.Find someone with a big lathe who is willing to help you.
    2. Unlace 410 rear wheel.
    3. Skim 5mm off the sprocket side!
    4.Relace said wheel
    Sorted!
    juicypips likes this.
