hello..I have a problem with my Husky.. I can't change my digital characteristics in speedometre from sm to te. i follow manual instrument but after step 3 , the operation jump step 8. I suppose the “passing”control is the switch on image 2 thank's and very sorry for my English. T.
I think that is the right button - you can also use the high-beams switch. It may be that your husky has the speedo found on the 630, which doesn't let you change SM to TE after it has been set the first time. broadwayron apparently tried on his 2009 610 and wasn't able to toggle SM/TE. On my 08 610 it lets me toggle between them no problems. You can see more on this thread: http://www.cafehusky.com/threads/speedo-change-te-to-sm.3226/.
everything ok..I followed the manual except for one thing,''The bike must be running", because is not written in instructions Thanks a lot
