125-200cc Husky WR 125-08: My TMXX carb is too short!!!
Discussion in '2 Stroke' started by Johnnymannen, Oct 16, 2011.
  1. Johnnymannen Husqvarna
    Sweden
    Hello everyone! Just changed carb on my sons WR125-08 from the old TMX to my factory TMXX from my 300. Works rea´lly well, but the carb is about 10mm too short on the airbox side. Does anyone have an easy solution to this? Incredible difference compared to the factory carb=)!
    Johnny
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Yes,
    You have to take the 2 lower air box bolts out on the lower rear aluminum subframe. Drill the holes closer to the front so air box moves forward. In the rear up under the top 2 bolts, you might have to put a washer to shim it forward. Usually, just doing the bottom works. Use blue loctite on bottom bolts.
    wallybean and john01 like this.
  3. john01 Husqvarna
    Powhatan VA
    Sounds like a plan to me; good luck Johnny.
  4. TROFFER88 Husqvarna
    Camas Wa
    Reed spacer
  5. wallybean Mini-Sponsor
    Montana
    Tim is going to use a reed spacer and it should work well. I am not sure how much it will affect throttle response on a 125.
  6. TROFFER88 Husqvarna
    Camas Wa
    I think I am going to install it on the manifold side .
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    The 7 port cylinders like the same gasket that goes between reed block and cylinder, then same gasket between reed block/carb boot. Pulls the reeds out at about right spot. I tried other spacers at my elevations and didn't notice a difference. Just with the gasket it made a difference. If you are using the v-force 2 block , set the reed limiters on low. If you space the reeds out to far, you'll have negative results. The more tension on the reeds = more low end. If it is set on low and you want to try the high setting, make sure you use new reeds cause they can crack.
  8. TROFFER88 Husqvarna
    Camas Wa
    Good to know thanks , it is the older cylinder so I don't know if that makes a difference. I am just trying to get the bike going until I do a winter Walt bigger bore kit .
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Great, keep us updated as you progress. Keep in mind, never give up trying different things. What works for me at sea level may not work in your elevations.
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Tim,
    Was doing some thinking, actually took a nap. There might be some advantages to a reed spacer up your higher elevations. Like to here how it works, etc....
  11. TROFFER88 Husqvarna
    Camas Wa
    Dartyppy,
    what would the advantages be, I was just going to use the reed spacer to make the carb fit. I have the Rb mods done to my Tmxx , I have the 16-62 needle and 5 slide , what jetting specs do you suggest.
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    That is good that you have the RB mods. Are you running the older V-Force 2 reed block? It has a high and low setting on the reed limiter plates. Make sure you set them on low. The V-Force 3 block is thicker, making up some difference. The 3 block, you cannot change tension on the reeds. Since the TMXX is a short bodied carb, it might benefit you in higher elevations lenghtening it (engine side of reed block). I put a gasket in front of reed block and one between reed block and intake boot. I think it worked some or my boot could of been leaking some air. On your jetting,maybe NW Rider/Walt and them can help you and they seem to run a lot lower pilots. Then depends on oil mix/race gas. I also look at the intake boot on the reed side. I kinda clean up the rubber casting, flow wise with a dremel tool. Then sand it real smooth so you have no air/fuel drag. You can tell by looking at it where you can improve it. Hope this helps.
    Thanx
    Darin
  13. Johnnymannen Husqvarna
    Sweden
    Ok! Sounds like an easy fix then! Thanks!
    Johnny
  14. Johnnymannen Husqvarna
    Sweden
    Thanks John! It was a big improvement with this carb as i had it laying around anyway:=)!
    Johnny
