250-500cc husky wr 300 gearbox fault
Discussion in '2 Stroke' started by reidy wr 300, Nov 30, 2013.
  1. reidy wr 300 Husqvarna
    wr 300
    montesa 4rt
    Hi there I have a wr 300 2011 I have a problem getting into second gear not every time but most times I get stuck in netrual and it takes a few seconds for it to go in when bike is stoped it goes through gears no problem checked oil for any metal shavings but oil is clean I am thinking it could be a bent selector any help or advise given I'd be very grateful
  2. Xcuvator Husqvarna
    Scholls Oregon
    yes
    There is a countersunk allen bolt that holds the selector star on the shift drum that has been known to come loose. I can't remember if the clutch has to come off to access it, but I think so.
  3. reidy wr 300 Husqvarna
    wr 300
    montesa 4rt
    Thank you so if I remove the clutch I should get access to the selector as not wanting to split engine if a can help it
  4. Xcuvator Husqvarna
    Scholls Oregon
    yes
    If that is the problem it will be an easy fix.:thumbsup:
  5. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
  6. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    Yep, definitely the issue. I had it as well.
    Pull the clutch, pull the inner clutch cover. Pull the shifter out of the way. Pull the bolt out, clean it up and lock tite the shit out of it, put it all back together, ride on.
