Want to lower the wr300 and need some advise on how to go about it, would like to put a spacer in the rear shock (sachs) and also inserts to the front forks (KYB 48mm). Does anyone have experience with this process and which kits are suitable/available?? I believe Zeta does kits but am unable to confirm if they fit the bike. Appreciate all info Cheers Paul
most lowering links only lower the machine a half inch..maybe an inch at the most. Not familiar with manufacturers who are currently offering lowering links for the old WR series. However, any competent suspension tuner should be able to space your forks and shock to lower your bike.
I used this on my WR300 2010: https://endurorecambios.com/es/reca...18649-bulon-rebaje-altura-para-husqvarna.html It only lowers 2cm but that was enough for me ... and it's very easy to do.
