Husqvarna 2011 TC449 generator and additional LED q?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Andrey Musinov, Jun 26, 2011.
  1. Andrey Musinov Husqvarna
    Perth, WA, Australia
    SMR510 2007
    Hello!
    I am from Russia, ask about Husqvarna 2011 TC449.
    I want to add LED light to front number plate.
    LED as examle "Vision X Solstice". May be this.
    Video for TE: http://www.youtube.com/watch?v=CLZipABHNQg
    Need: 9-50V and light use only 0.75 amps. Want connect direct to battary.
    Will the bike this load generator? It will not be any problems for the injector? I could not find the technical data about generator for my TC449. Ideally, we would put two of these LED lamps.
    Yet sometimes we go with enduros, and light means safety.
    Thanks! Andrey.
  2. Andrey Musinov Husqvarna
    SMR510 2007
    Find MOUNT KIT COMBO PACK mounting on the wheel. On ebay item number 230630680112 price 50 $us. So can not spoil the plastic for the number.
  3. Harbinger Hróðvitnir
    Tromsø, Norway
    2013 Nuda 900 R
    Buell
    Hi Andrey, you need to check out how many amps your battery is producing. Since your bike has an electric starter i guess it will be OK to hook them up to the battery since they do not draw much power at all, just make sure that you mount it up with a handlebar switch so that you can turn off the ligths when you don`t need them or it will drain your battery.:thumbsup:
    check out this kit
    http://www.visionxstore.com/Motorcycle LED Lights?product_id=671
