CR125 Husqvarna CR 125Engine Type 2-stroke single cylinder.Bore / stroke 54 mm x 54.5 mm (2.12 in x 2.14 in)Displacement 124.82 ccCompression ratio 8.8:1Mixture control / engine management Carburettor, Reed valve / electronic engine management, variable advance.Starting Kick start.Cooling Liquid cooling.Homologation No homologation, USA: Red sticker.Transmission Clutch Wet, multiplate type.Gearbox Constant mesh 6-speed gearbox.Final drive ratio 13T / 50T (3.846)Chassis / brakes Frame Steel single tube. Aluminium alloy rear subframe.Front suspension Kayaba upside-down telescopic closed cartridge fork; compression and rebound damping adjustment; ø 48 mmRear suspension Sachs single hydraulic shock absorber; spring preload adjustment, rebound and compression damping adjustment.Front suspension travel 300 mm (11.8 in)Rear suspension travel 296 mm (11.6 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x19"Tyres, front 80/100 - 21"Tyres, rear 100/90 - 19"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type with hydraulic control and floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type with hydraulic control and floating caliper.Dimensions / weight Wheelbase 1.460 mm (57.48 in)Seat height, unladen weight 985 mm (38.78 in)Ground clearance, unladen weight 325 mm (12.79 in)Trail 111 mm (4.37 in)Rake 26.5°Dry weight 94 Kg (207.24 lb)Fuel tank capacity 7 l (US gallons: 1.85 - Imp. gallons 1.54)
TC250R Husqvarna TC 250 REngine Type 4-stroke single cylinder, four valves per cylinder, two overhead camshafts, wet sump lubrication.Bore / stroke 79 mm x 50.9 mm (3.11 in x 2 in)Displacement 249.5 ccCompression ratio 13.5:1Mixture control / engine management Electronic injection / digital engine management, capacitive discharge ignition, with variable advance.Starting Kick start.Cooling Liquid cooling.Homologation No homologation, USA: Red sticker.Transmission Clutch Wet, multiplate type, hydraulic control.Gearbox Constant mesh 5-speed gearbox.Final drive ratio 13T / 50T (3.846)Chassis / brakes Frame Steel single tube. Aluminium rear subframe.Front suspension Kayaba upside-down telescopic closed cartridge fork; compression and rebound damping adjustment; ø 48 mm.Rear suspension Kayaba progressive "Soft Damp" type with single hydraulic shock absorber; spring preload adjustment, rebound damping adjustment, and compression damping adjustment for low-speed and high-speed.Front suspension travel 300 mm (11.81 in)Rear suspension travel 296 mm (11.6 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 1.85"x19"Tyres, front 80/100 - 21"Tyres, rear 100/90 - 19"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type, with hydraulic control and double piston floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type, with hydraulic control and single piston floating caliper.Dimensions / weight Wheelbase 1.460 mm (57.48 in)Seat height, unladen weight 985 mm (38.78 in)Ground clearance, unladen weight 325 mm (12.79 in)Trail 111 mm (4.37 in)Rake 26,5°Dry weight 101 Kg (222.67 lb)Fuel tank capacity 6.5 l (US gallons: 1.72 - Imp. gallons 1.43)
TC449 Husqvarna TC 449Engine Type 4-stroke single cylinder, four valves per cylinder, two overhead camshafts, wet sump lubrication.Bore / stroke 98 mm x 59.6 mm (3.86 in x 2.35 in)Displacement 449.6 ccCompression ratio 13:1Mixture control / engine management Electronic injection / digital engine management, capacitive discharge ignition, with variable advance.Starting Electric.Cooling Liquid cooling.Homologation No homologation, USA: Red sticker.Transmission Clutch Wet, multiplate type, hydraulic control.Gearbox Constant mesh 5-speed gearbox.Final drive ratio 15T / 53T (3.530)Chassis / brakes Frame Steel single tube. Aluminium rear subframe.Front suspension Kayaba upside-down telescopic closed cartridge fork; compression and rebound damping adjustment; ø 48 mm.Rear suspension Kayaba progressive type with single hydraulic shock absorber; spring preload adjustment, rebound damping adjustment, and compression damping adjustment for low-speed and high-speed.Front suspension travel 300 mm (11.81 in)Rear suspension travel 300 mm (11.81 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x19"Tyres, front 80/100 - 21"Tyres, rear 110/90 - 19"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type, with hydraulic control and double piston floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type, with hydraulic control and single piston floating caliper.Dimensions / weight Wheelbase 1.490 mm (58.66 in)Seat height, unladen weight 963 mm (37.91 in)Ground clearance, unladen weight 335 mm (13.19 in)Trail 101 mm (3.98 in)Rake 25.8°Dry weight 108 Kg (238.1 lb)Fuel tank capacity 8 l (US gallons: 2.11 - Imp. gallons 1.76)
TE449 Husqvarna TE 449Engine Type 4-stroke single cylinder, four valves per cylinder, two overhead camshafts, wet sump lubrication.Bore / stroke 98 mm x 59.6 mm (3.86 in x 2.35 in)Displacement 449.6 ccCompression ratio 12:1Mixture control / engine management Electronic injection / digital engine management, capacitive discharge ignition, with variable advance.Starting Electric.Cooling Liquid cooling.Homologation Euro 3, USA: Street legal.Transmission Clutch Wet, multiplate type, hydraulic control.Gearbox Constant mesh 6-speed gearbox.Final drive ratio 15T / 51T (3.4)Chassis / brakes Frame Steel single tube. Aluminium rear subframe.Front suspension Kayaba upside-down telescopic open cartridge fork; compression and rebound damping adjustment; ø 48 mm.Rear suspension Kayaba progressive type with single hydraulic shock absorber; spring preload adjustment, rebound damping adjustment, and compression damping adjustment for low-speed and high-speed.Front suspension travel 300 mm (11.81 in)Rear suspension travel 293 mm (11.53 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 90/90 - 21"Tyres, rear 140/80 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type, with hydraulic control and double piston floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type, with hydraulic control and single piston floating caliper.Dimensions / weight Wheelbase 1.490 mm (58.66 in)Seat height, unladen weight 952 mm (37.48 in)Ground clearance, unladen weight 333 mm (13.11 in)Trail 101 mm (3.98 in)Rake 25.8°Dry weight 113 Kg (249.12 lb) - USA: 116 Kg (255.74 lb)Fuel tank capacity 8.5 l (US gallons: 2.25 - Imp. gallons 1.87)
TE 511 Husqvarna TE 511Engine Type 4-stroke single cylinder, four valves per cylinder, two overhead camshafts, wet sump lubrication.Bore / stroke 101 mm x 59.6 mm (3.98 in x 2.35 in)Displacement 477.5 ccCompression ratio 12:1Mixture control / engine management Electronic injection / digital engine management, capacitive discharge ignition, with variable advance.Starting Electric.Cooling Liquid cooling.Homologation Euro 3, USA: Red sticker.Transmission Clutch Wet, multiplate type, hydraulic control.Gearbox Constant mesh 6-speed gearbox.Final drive ratio 15T / 51T (3.4)Chassis / brakes Frame Steel single tube. Aluminium rear subframe.Front suspension Kayaba upside-down telescopic open cartridge fork; compression and rebound damping adjustment; ø 48 mm.Rear suspension Kayaba progressive type with single hydraulic shock absorber; spring preload adjustment, rebound damping adjustment, and compression damping adjustment for low-speed and high-speed.Front suspension travel 300 mm (11.81 in)Rear suspension travel 293 mm (11.53 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 90/90 - 21"Tyres, rear 140/80 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type, with hydraulic control and double piston floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type, with hydraulic control and single piston floating caliper.Dimensions / weight Wheelbase 1.490 mm (58.66 in)Seat height, unladen weight 952 mm (37.48 in)Ground clearance, unladen weight 333 mm (13.11 in)Trail 101 mm (3.98 in)Rake 25.8°Dry weight 113 Kg (249.12 lb) - USA: 116 Kg (255.74 lb)Fuel tank capacity 8.5 l (US gallons: 2.25 - Imp. gallons 1.87)
WR 125 Husqvarna WR 125Engine Type 2-stroke single cylinder.Bore / stroke 54 mm x 54.5 mm (2.12 in x 2.14 in)Displacement 124.82 ccCompression ratio 8.8:1Mixture control / engine management Carburettor, Reed valve / electronic engine management, variable advance.Starting Kick start.Cooling Liquid cooling.Homologation Euro 3, USA: Red sticker.Transmission Clutch Wet, multiplate type.Gearbox Constant mesh 6-speed gearbox.Final drive ratio 13T / 50T (3.846)Chassis / brakes Frame Steel single tube. Aluminium alloy rear subframe.Front suspension Kayaba upside-down telescopic open cartridge fork; compression and rebound damping adjustment; ø 48 mmRear suspension Sachs single hydraulic shock absorber; spring preload adjustment, rebound and compression damping adjustment.Front suspension travel 300 mm (11.8 in)Rear suspension travel 296 mm (11.6 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 90/90 - 21"Tyres, rear 120/90 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type with hydraulic control and floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type with hydraulic control and floating caliper.Dimensions / weight Wheelbase 1.465 mm (57.68 in)Seat height, unladen weight 975 mm (38.38 in)Ground clearance, unladen weight 325 mm (12.79 in)Trail 110 mm (4.33 in)Rake 26.5°Dry weight 98 Kg (216.05 lb)Fuel tank capacity 9.5 l (US gallons: 2.51 - Imp. gallons 2.09)
WR 250 Husqvarna WR 250Engine Type 2-stroke single cylinder.Bore / stroke 66.4 mm x 72 mm (2.61 in x 2.83 in)Displacement 249.3 ccCompression ratio 8.4:1Mixture control / engine management Carburettor, Reed valve / digital engine management, variable advance.Starting Kick start.Cooling Liquid cooling.Homologation Euro 3, USA: Red sticker.Transmission Clutch Wet, multiplate type.Gearbox Constant mesh 5-speed gearbox.Final drive ratio 13T / 48T (3.692)Chassis / brakes Frame Steel single tube. Aluminium alloy rear subframe.Front suspension Kayaba upside-down telescopic open cartridge fork; compression and rebound damping adjustment; ø 48 mmRear suspension Sachs single hydraulic shock absorber; spring preload adjustment, rebound and compression damping adjustment.Front suspension travel 300 mm (11.8 in)Rear suspension travel 305 mm (12 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 90/90 - 21"Tyres, rear 140/80 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type with hydraulic control and floating caliper.Brake, rear 220 mm (8.66 in) fixed disc, with hydraulic control and floating caliper.Dimensions / weight Wheelbase 1.485 mm (58.46 in)Seat height, unladen weight 985 mm (38.76 in)Ground clearance, unladen weight 345 mm (13.58 in)Trail 100 mm (3.93 in)Rake 27°Dry weight 104 Kg (229.28 lb)Fuel tank capacity 9.5 l (US gallons: 2.51 - Imp. gallons 2.09)
WR 300 Husqvarna WR 300Engine Type 2-stroke single cylinder.Bore / stroke 72 mm x 72 mm (2.83 in x 2.83 in)Displacement 293.1 ccCompression ratio 6.9:1Mixture control / engine management Carburettor, Reed valve / digital engine management, variable advance.Starting Kick start.Cooling Liquid cooling.Homologation Euro 3, Usa: Red sticker.Transmission Clutch Wet, multiplate type.Gearbox Constant mesh 5-speed gearbox.Final drive ratio 13T / 48T (3.692)Chassis / brakes Frame Steel single tube. Aluminium alloy rear subframe.Front suspension Kayaba upside-down telescopic open cartridge fork; compression and rebound damping adjustment; ø 48 mmRear suspension Sachs single hydraulic shock absorber; spring preload adjustment, rebound and compression damping adjustment.Front suspension travel 300 mm (11.8 in)Rear suspension travel 305 mm (12 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 90/90 - 21"Tyres, rear 140/80 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type with hydraulic control and floating caliper.Brake, rear 220 mm (8.66 in) fixed disc, with hydraulic control and floating caliper.Dimensions / weight Wheelbase 1.485 mm (58.46 in)Seat height, unladen weight 985 mm (38.76 in)Ground clearance, unladen weight 345 mm (13.58 in)Trail 100 mm (3.93 in)Rake 27°Dry weight 104 Kg (229.28 lb)Fuel tank capacity 9.5 l (US gallons: 2.51 - Imp. gallons 2.09)
I guess the photographer's memory card ran out before he/she got to the rest of the models. :/ TE 250R Husqvarna TE 250 REngine Type 4-stroke single cylinder, four valves per cylinder, two overhead camshafts, wet sump lubrication.Bore / stroke 79 mm x 50.9 mm (3.11 in x 2 in)Displacement 249.5 ccCompression ratio 13.5:1Mixture control / engine management Electronic injection / digital engine management, capacitive discharge ignition, with variable advance.Starting Electric and kick start.Cooling Liquid cooling.Homologation Euro 3Transmission Clutch Wet, multiplate type, hydraulic control.Gearbox Constant mesh 6-speed gearbox.Final drive ratio 13T / 40T (3.076)Chassis / brakes Frame Steel single tube. Aluminium rear subframe.Front suspension Kayaba upside-down telescopic open cartridge fork; compression and rebound damping adjustment; ø 48 mm.Rear suspension Kayaba progressive "Soft Damp" type with single hydraulic shock absorber; spring preload adjustment, rebound damping adjustment, and compression damping adjustment for low-speed and high-speed.Front suspension travel 300 mm (11.81 in)Rear suspension travel 296 mm (11.6 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 90/90 - 21"Tyres, rear 120/90 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type, with hydraulic control and double piston floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type, with hydraulic control and single piston floating caliper.Dimensions / weight Wheelbase 1.470 mm (57.87 in)Seat height, unladen weight 950 mm (37.40 in)Ground clearance, unladen weight 290 mm (11.42 in)Trail 106 mm (4.17 in)Rake 26.5°Dry weight 109 Kg (240.3 lb)Fuel tank capacity 8.5 l (US gallons: 2.25 - Imp. gallons 1.87)
TE 310R Husqvarna TE 310 REngine Type 4-stroke single cylinder, four valves per cylinder, two overhead camshafts, wet sump lubrication.Bore / stroke 82 mm x 57.35 mm (3.23 in x 2.26 in)Displacement 302.44 ccCompression ratio 13.1:1Mixture control / engine management Electronic injection / digital engine management, capacitive discharge ignition, with variable advance.Starting Electric and kick start.Cooling Liquid cooling.Homologation Euro 3, USA: Street Legal.Transmission Clutch Wet, multiplate type, hydraulic control.Gearbox Constant mesh 6-speed gearbox.Final drive ratio 13T / 40T (3.076)Chassis / brakes Frame Steel single tube. Aluminium rear subframe.Front suspension Kayaba upside-down telescopic open cartridge fork; compression and rebound damping adjustment; ø 48 mm.Rear suspension Kayaba progressive "Soft Damp" type with single hydraulic shock absorber; spring preload adjustment, rebound damping adjustment, and compression damping adjustment for low-speed and high-speed.Front suspension travel 300 mm (11.81 in)Rear suspension travel 296 mm (11.6 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 90/90 - 21"Tyres, rear 120/90 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type, with hydraulic control and double piston floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type, with hydraulic control and single piston floating caliper.Dimensions / weight Wheelbase 1.470 mm (57.87 in)Seat height, unladen weight 950 mm (37.40 in)Ground clearance, unladen weight 290 mm (11.42 in)Trail 106 mm (4.17 in)Rake 26.5°Dry weight 109 Kg (240.3 lb) - USA: 112 Kg (246.92 lb)Fuel tank capacity 8.5 l (US gallons: 2.25 - Imp. gallons 1.87)
TXC 250R Husqvarna TXC 250 REngine Type 4-stroke single cylinder, four valves per cylinder, two overhead camshafts, wet sump lubrication.Bore / stroke 79 mm x 50.9 mm (3.11 in x 2 in)Displacement 249.5 ccCompression ratio 13.5:1Mixture control / engine management Electronic injection / digital engine management, capacitive discharge ignition, with variable advance.Starting Electric and kick start.Cooling Liquid cooling.Homologation No homologation, USA: Red sticker.Transmission Clutch Wet, multiplate type, hydraulic control.Gearbox Constant mesh 6-speed gearbox.Final drive ratio 13T / 50T (3.846)Chassis / brakes Frame Steel single tube. Aluminium rear subframe.Front suspension Kayaba upside-down telescopic closed cartridge fork; compression and rebound damping adjustment; ø 48 mm.Rear suspension Kayaba progressive "Soft Damp" type with single hydraulic shock absorber; spring preload adjustment, rebound damping adjustment, and compression damping adjustment for low-speed and high-speed.Front suspension travel 300 mm (11.81 in)Rear suspension travel 296 mm (11.6 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 80/1000 - 21"Tyres, rear 110/100 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type, with hydraulic control and double piston floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type, with hydraulic control and single piston floating caliper.Dimensions / weight Wheelbase 1.470 mm (57.87 in)Seat height, unladen weight 950 mm (37.40 in)Ground clearance, unladen weight 290 mm (11.42 in)Trail 106 mm (4.17 in)Rake 26.5°Dry weight 105 Kg (231.49 lb)Fuel tank capacity 8.5 l (US gallons: 2.25 - Imp. gallons 1.87)
TXC 310R Husqvarna TXC 310 REngine Type 4-stroke single cylinder, four valves per cylinder, two overhead camshafts, wet sump lubrication.Bore / stroke 82 mm x 57.35 mm (3.23 in x 2.26 in)Displacement 302.44 ccCompression ratio 13:1Mixture control / engine management Electronic injection / digital engine management, capacitive discharge ignition, with variable advance.Starting Electric and kick start.Cooling Liquid cooling.Homologation No homologation, USA: Red sticker.Transmission Clutch Wet, multiplate type, hydraulic control.Gearbox Constant mesh 6-speed gearbox.Final drive ratio 13T / 50T (3.846)Chassis / brakes Frame Steel single tube. Aluminium rear subframe.Front suspension Kayaba upside-down telescopic closed cartridge fork; compression and rebound damping adjustment; ø 48 mm.Rear suspension Kayaba progressive "Soft Damp" type with single hydraulic shock absorber; spring preload adjustment, rebound damping adjustment, and compression damping adjustment for low-speed and high-speed.Front suspension travel 300 mm (11.81 in)Rear suspension travel 296 mm (11.6 in)Wheels Aluminium alloy spoked wheels.Rim, front 1.60"x21"Rim, rear 2.15"x18"Tyres, front 80/1000 - 21"Tyres, rear 110/100 - 18"Brake, front 260 mm (10.24 in) fixed disc, "Wave" type, with hydraulic control and double piston floating caliper.Brake, rear 240 mm (9.45 in) fixed disc, "Wave" type, with hydraulic control and single piston floating caliper.Dimensions / weight Wheelbase 1.470 mm (57.87 in)Seat height, unladen weight 950 mm (37.40 in)Ground clearance, unladen weight 290 mm (11.42 in)Trail 106 mm (4.17 in)Rake 26.5°Dry weight 105 Kg (231.49 lb)Fuel tank capacity 8.5 l (US gallons: 2.25 - Imp. gallons 1.87)
Same 2 strokes as last year and the year before and the year before that.Looks like I will just keep riding my 2008 with the 165 kit.I really need to get a new bike I have not received any husky bucks since 2009 Even tho I got some wins
Sounds like a good enough reason to buy a new bike ... I'd like to have another one of these 2T machines to keep and ride for the next decade but I'd want a used model .... Maybe Husky should just drop the prices so low on the 2T machines, you just gotta buy one ...
