125-200cc Husqvarna cr 144 shift issues after rebuild
Discussion in '2 Stroke' started by balderHSQ, Feb 5, 2017.
  1. balderHSQ Husqvarna
    husqvarna sms 125 with cr 125 engine
    non
    Hey guys! i just did a full rebuild on my cr 144 engine. but my promlem is that i cant shit it into neutral and only a few gears are working propely.. any sugestions on what could be wrong? any help would be appreciated.
    sorry for my bad english
  2. wallybean Mini-Sponsor
    Montana
    I guess you need to give us a little more information. Did you split the cases to rebuild your bottom end?
  3. Sendman Husqvarna
    Ukraine
    Husky 144
    I know what a problem... have the same!
    Take a look at this photos.
    Notice the thickness of gasket...
    So when i rebuild my - i was using sealant (as usually do this parts), but the clearance between parts on photo goes way small, and gears stopped shifting.
    So next step - i trim a little bit from side cover, to compensate gasket thickness, and to use sealant. You can just use new gasket. But i trim it, to forget it)
  4. R_Little Husqvarna
    NJ
    That's a side cover gasket and I doubt it make much difference.
    Did you loose a shim on the end of the transmission shaft, or put the shift forks in backwards
    You have to take it apart and reassemble W/O the crank in and make sure it shifts before you put the crank in.
    If it shifted before it will shift again.
