husqvarna shrouds in tight woods riding annoying broken tabs
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by dan s, Oct 1, 2012.
  1. dan s Husqvarna
    united states N.J
    2013 wr 250 A-Class
    I'm a new husqvarna owner and ride a lot of tight trails here in south jersey and discovered how much of a pain the shrouds are since they stick out so far and they are two pieces that fit together by a little plastic tab that broke off almost instantly.I came up with an little easy solution and all though it is minor I thought I would share.I took two pieces of thin aluminum maybe about a 1/16 thick and 1 inch wide and bent them in the vise so there is about a 1/8 slot for the black tab on the lower shroud will slip into.Feels a lot stronger but can still pull out on a big hit.You can either use two small screws or rivet them on.
    OlderHuskyRider, ray_ray and Coffee like this.
  2. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    Is your bike in your lounge room?
    Blakelpd5 likes this.
  3. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    I like the idea, but lets see a pic of the other side...
    Here was my solution:
    Before:
    After:
  4. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    heat em up with a hairdryer or heat gun & bend em inwards, makes a big difference! did this after i broke them however :)
  5. dfeckel Husqvarna
    Medford, NJ
    I drill two holes in the lower shroud and two holes in the upper shroud and run cable ties between them. Put the one cable tie as close as possible to the front to keep foliage from catching in between. I have to cut them to remove the tank, so I keep a couple with me on the trail just in case. This setup is super strong and will prevent broken shrouds as well as bent tabs on the radiators.
    ray_ray likes this.
  6. dan s Husqvarna
    united states N.J
    2013 wr 250 A-Class
    That's a good idea with the zip tie now that I think about it every ride I'm pulling brush from in between the two pieces.
  7. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I ripped mine off on the second ride.:doh: I never fixed them yet, but may try one of these fixes. Strangely, it only happened on my WR300. I have ridden my TE450 in the same places, and have had the bike since it was new in 2007....but no damage to that one yet.:rolleyes:
  8. justplayin Husqvarna
    SNJ
    I broke mine too very shortly after I got my 07 TE450....did a similar zip tie thing. Waiting to break them on my 12 Wr144.......it's coming.....I gave up on having good looking plastics and shiney decals on my woods bikes back when I was a B rider....you get to a point that you realize that it is a very expensive and never ending battle to look "pretty" when riding trails........I don't even wash them until I need to work on them.
    dave lindsey and Blakelpd5 like this.
  9. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    Lookin pretty is for them track boys...
    ray_ray likes this.
  10. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    I've got duct tape holding my right one on. It ripped off where it bolts to the tank.
  11. justpinit Husqvarna
    Maryland
    2012 wr 300
    93 kx 125 with a kdx 200 engine.
    Don't you're pants get caught on the bottom part of the upper shroud? Mine do and i still have both pieces in tact.Why can't husky make a one piece shroud, my bike always looks like crap because of this.In the last HS i did the front inch and a half of the upper right shroud got broken off. This is really dumb s@#t..
  12. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    Never had my pants get caught. And those are my back-up pants. My normal pants are over-the-boot and even baggier, but again, never had that happen.
  13. Grant starr Husqvarna
    Venus Bay, Victoria, Australia
    2010 TE 250
    2004 te 250, 2001 klx 400, 92 TT350
    A Better idea is to just drill 2 hole in lower shroud and cable tie to slot in upper shroud on inside unless already broken, at least this way you wont see it from the outside!
  14. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    I noticed on the FAR bikes they pop riveted the uppers & lowers together, just remove as one unit I guess................
  15. Joe Chod Husqvarna
    upstate NY
    I just stay out of New Jersey! :banana::lol::applause::cheers:
  16. K5PL5 Husqvarna
    Palmyra, PA
    2012 WR300
    I ride in Eastern PA in the coal region single track trails and always come back with some tree bits and the tabs apart on the WR. Im gonna trim them down and rivet those things. Gdamn middle bolts in the gas tank wouldnt come out either so the shroud rests over the bolts. That kills me! Anyone ever come up with a solution or technique to get those bolts out of the tank? The nutserts on my tank just spin and spin...
  17. Grant starr Husqvarna
    2010 TE 250
  18. Grant starr Husqvarna
    2010 TE 250
    Hi guys just posted these pics of how I cable tie top shroud to lower shroud so you don't see anything from the outside of shrouds!
    GrooveThang likes this.
  19. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    That would be great if I still had the red part intact that you have the black part ziptied to.:excuseme:
    shawbagga likes this.
