125-200cc Husqvarna SM125 2005 charging problem
Discussion in '2 Stroke' started by Jontteyy, Apr 16, 2016.
  1. Jontteyy Husqvarna
    Husqvarna SM/CR125 -05
    Hello!
    I have Husqvarna SM125 from 2005. I've had it for 2 years, and rebuilt the whole thing last winter. Now I'm having problems with charging the battery. Battery should be fine, it charges fine with external charger. I have tried different regulator and stator, both were used ones, so I can't be sure about their condition, but sellers told me those are working parts. I can't find any damage from my stator, coil seems to be in good condition. Also, my old stator works on my friends bike.
    My flywheel has some scratches on magnet surface, could those affect to charging? Ignition works perfectly. There is two yellow wires coming from stator, no voltage coming there.
    Could it be some grounding problem or something? Is there some wires that can be connected wrong? I have triple checked all the grounding wires and other connectors. I have tried other wiring harness, same problem.
    Other question:
    I attached picture about my speedometer. There is option for tachometer, but it's not connected on SM125 stock, does anybody know how could I connect it and get it working?
  2. Jontteyy Husqvarna
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Scratches on magnets shouldnt bother it, as the way that works is a gap in the magnets induces a current through the stator coils as it passes like a reverse electro magnet. Or thats what i believe.
    Your battery leads are ok not trapped anywhere, check the continuity with a multimeter.
    Your batteries hooked up correctly too right? I know it sounds like im accusing you of being an idiot but im not and we have all overlooked simple things.
    If your stator charges on another machine its not your stator so that narrows that out.
    So just cables battery and rectifyer really left.
    Try hooking your mates battery up to yours and see if that charges up? Could of lost the gel inside it or just died.
    Good luck.
