Hi, I just installed full Arrow factory exhaust system on my bike and didnt notice much difference even with the ECU that comes with it. Do i just need iBeat to tune it or should I get the power commander 5? I know nuts bout EFI. Thanks.
You need to set the TPS up at least with Ibeat- cause your ECU which came from the factory has to be set to your tps voltage- I'd also set the WOT to 100.2 while doing so. Then you can play with fueling- with JD, PCommander, or Ibeat, if need be.
Thanks. Adjusted my TPS just now at the bike shop. Bow thinking of getting PC 5, is the autotune also neccessary?
Wide Open Throttle- on Ibeat there's a throttle % reading and you can adjust the TPS hardstop screw to achieve different settings- 100.2% WOT has been found to be a good standard for that setting. I don't have a power commander- but since its adjustments are so vast- you either need a Dyno or the Auto Tune to really take advantage of its adjustment capability.
