Husqvarna TE 310R 2014 oil drain plug
Use #24 for each dump and check the screen #21 on first oil/filter change and maybe every other oil change. Initially excercise care when removing #22 as some have had issues rounding the nut. Remove hose first makes it easier and good to have a good quality low profile closed wrench for it.
I check the oil screen #21 every oil change, it is the pre-filter for the oil pump. I know it's a pita.
Is there any reason not to put a magnet on each of these drain plugs? On the 250 drain plug without the hose barb.
The magnets tend to come loose on occaision and it would go directly into the oil pump.
Be very careful not to over-tighten #22. Use high quality spanners when removing #22 - do a bit of research & you will find that it is common to round the nut off the spigot making it really challenging to remove. Mine was ultra tight from the factory - I have a new one coming due to rounding the nut.
My dealer tells me just 2 finger pressure on the spanner - it cant back out anyway due to the oil line. What surprised me was when I tightened it with 2 finger pressure, it was quite difficult to remove again just 1 minute later ... try it & you will see what I mean.
Ian
Just tighten #24 with an allen wrench so that you can remove it with same tool later. Torqued from the factory like #22 is very tight.
