Husqvarna TE610 fuel lines
Discussion in '610/630' started by Bullatthegate, Feb 16, 2016.
  1. Bullatthegate Husqvarna
    Willawarrin
    TE610
    G'day all I am new here and I am slowly doing up my bike and now putting it back together but unfortunately I can't remember where the fuel lines go. I have the "In" and the "out" lines stamped next to the barbs on the tank but is "In" the fuel return or into the motor? One line is poly ethylene and it seems to go up to a vacuum diaphragm which I would assume is the fuel return ?
    Any help would be greatly appreciated as I can then start it for the first time !
    Thanks
    Mick
  2. Bullatthegate Husqvarna
    Willawarrin
    TE610
    Finally worked it out .The poly hose has another connector that goes onto it which then goes onto the tank.
    Problem solved
