Husqvarna TR 650 Terra | Play in clutch actuator
Discussion in 'TR650' started by risinqsun, May 31, 2019.
  1. risinqsun Husqvarna
    TR 650 Terra
    Hey guys,
    I'm currently checking over my engine. While removing my clutch discs, I discovered that the actuator rack of the clutch mechanism has lot's of play in the bearing.
    I measured the bearing, it's 15 mm inside (like it's supposed to be).
    The shaft itself is only 14 mm, but doesn't show any signs of wear.
    Is this correct like it is? With 1 mm of play, it moves around a lot. Yes, it will be centered by the clutch cover hole, but I just wanted to verify that this is normal.
    See the pictures for a better understanding.
    Thanks a lot,
    Flo
  2. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    Wow, that doesn't look right!
    I have no advice.
  3. CarstenB Husqvarna
    NL
    F650GS Dakar
    That's perfectly normal, i just checked on a spare clutch. The bearing only receives axial load. Voll normaaal ey....
