250-500cc Husqvarna WR 360 200 Rebuild
Discussion in '2 Stroke' started by EURO1215, Jan 12, 2015.
  1. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Hello everyone , wanted to share my rebuild. For now its just an connection rod that i payed 300€ for. i was very surprised when the original came and i compared it with the old one , it seems like the last owner already had the rod seized , soo he drilled a hole in it , put a bigger bearing , and did homemade tenon. soo last owner didnt wanted to spend money for the repair , and did this and expected that it will break in few months and wanted to get rid of it and sold it to me... heres few pics from my rebuild .)
    when the bike will be finished ill be selling it
    juicypips likes this.
  2. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
  3. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Good effort, dont forget the shims on gear clusters upon reassembly otherwise you could cause binding in the gear box.
  5. Mikey465 Husqvarna
    New Zealand
    WR360
    You've already got one of the hardest parts to find sorted now, so you can fix her up and have a darn good bike.
    Put it back together with proper gaskets plus fresh seals ,bearings and piston and your set.
    Just be careful if you lift out the gears as the end ones have loose needles and can fall off the shaft if you don't tie the cluster together.
    You might also want to check out decompressor threads on here to make it easier to kick start once its been refreshed.
  6. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Okay , shims on gear clusters , thanks ! .)
    okay thank you , i will try to be careful about the gears,--- i think one shim already falled and i hope its on the right place , does anyone have pic or schema how the gears should be with the shims and all the stuff ?
    yes decompressor would be fine , might give it a look
    another question --- i found in my mind is that if i need to make an break in procedure or something after the first start with new con rod ? or is it needed just when you replace piston ?
  7. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    butchery is a shame
    but once you get it right you might fall in love with the bike
    ditto on the decompressor mod
    trying to do one for my 99 360
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Ive got a set apart at the moment will post pic with locations asap, just warming up feet on oil heater.
  9. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    The important thing is the two shims on the right side of clutch stack gears. Ones wafer thin the others four times as thick.
    Cant go too far wrong really as all diameters are different.
    Any other pics needed??
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thats the same gear you wanna worry about loosing the needles from if i remember correctly theres about 31-36 of em.
    The other set you can swing about allday its a cages needle roller then the rest are circliped on.
    Also make sure the end gear has the chamfered edge of teeth towards the other gears otherwise you will bind them up and cause no end of bad juju to your engine.
    Motosportz likes this.
  11. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Okay thanks ! That should definately help. Ill write as soon as ill get back home and get into it
  12. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    got the conrod together ! will post pics soon
  13. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Conrod with crankshaft , plus new bearings for the shaft
  14. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Got the engine together ! also bought and replaced all of the bearings in gearbox .)
    the bike should be done tomorrow
  15. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Every bearing in the box! Good effort how did you get the clutch actuator on out i never did manage to replace mine..
    Keep us posted on how it performs.
  16. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Gear box pics is without the new bearings .( was too rushy to take photos of the new ones
    also not sure what is clutch actuator ?
  17. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    You know the rod that goes all the way through the clutch gear set? It bares on a ball bearing clutch side and a rod on the other side the thing wich the clutch cable hooks onto. Thats the actuator in my book may be called something else.
  18. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    oh ! thats the part i didnt even tryed to get out .D totaly forgot about that , maan sorry but i have no idea
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Just being pedantic, i dont think anyone has a method to replace those without damaging the cases.
    the top one maybe but the tiny needle roller at the bottom no got a clue.
    EURO1215 likes this.
  20. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Got her running today ! the piston is bit ringing ... which means ill buy one soon and replace it too. but otherwise everything sounded just good !
    Did 1:30 , started it , it bit yelled from beggining and got okay again in 2 seconds, then waited bit more because it was running in high rpms , then i started to 1/3randomly push throttle for 5 minutes till it heated up. turned off , and gonna do the same tomorrow, also change an oil tomorrow and give it an test ride .)
    Motosportz and juicypips like this.
