125-200cc Husqvarna Wr300 Shock Seal Head
Discussion in '2 Stroke' started by Single Track, Feb 10, 2021.
  1. Single Track Husqvarna
    wr300
    Riders,
    Any idea where i can source (in Canada) a seal head or shock rebuild kit for 2009 Husqvarna WR300 with a Sachs shock?
    Thanks in advance!
  2. Chisler Husqvarna
    British Columbia, Chilliwack River Valley
    2010 WR 300 Husqvarna
    You can ask Rod ... www.rmrsuspension.com he set up my 2010 Wr 300 including lowering it 25mm
    did an awesome job, he may have what your looking for.
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    If nothing else,https://www.allballsracing.com/ probably has something that will work. I didn't want to use the expensive stock components to rebuild my 07 TE450 seal head, so I found a seal head that would fit from these people, and modified the shock so that it would work. I had to throw out the top out spring and shaft circlip, and stack flow-through teflon bushings (the kind that are used to shorten the length, and lower the seat height) on the shaft to achieve the correct length, but it worked out great, and now I have a nice inexpensive sealhead that is easy to replace. The two most crucial measurements are the shaft diameter and the body ID. You can figure out what you need from there, with the help of somebody who knows the part numbers at that company.
