250-500cc Hydraulic clutch conversion for WR360 - details wanted
Discussion in '2 Stroke' started by Leepet, Feb 17, 2013.
  1. Leepet Husqvarna
    Hi, I'm looking to do a hydraulic clutch conversion on my WR360 so I can install a Clake on it.
    I've heard of people using Hebo and Magura kits but havent been able to get any specifics.
    Has anyone here done the conversion? If so, can you tell me what kit you used, who you got it from and whether you had any issues with it?
    Cheers
    Pete
  2. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
  3. husky3002t Husqvarna
    wr300
  4. SmokeyExpress Husqvarna
    Canberra Australia
    2014 WR300, 1996 WR360,2013 WR125
    I tried to fit a Magura Hydo Clutch to my 1996 360 & I found that it didn't fit, at least not well or easily. The main problem is that there is a coolant hose that is right in the way. The 360 engine is quite a bit different to the newer 250's & 300's. You may be able to fit the slave cylinder is you remove the hose, but it will be a bit of a pain as you would have to drop your coolant. I decided that it wasn't worth it so I didn't pursue it further. Just make sure you can get your money back if it doesn't fit. :)
