125-200cc Hydraulic clutch for wr150
Discussion in '2 Stroke' started by huskybear, May 12, 2013.
  1. huskybear Husqvarna
    B.C. Canada
    Playing with the idea of putting a hydraulic clutch on my 2010 wr150. I have a magura hydraulic master cylinder and lever assembly as a spare for my husaberg. Does any-one know what line and slave cylinder assembly is required to do this and where to purchase parts? Thanks:cheers:
  2. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    On my 144 I have a AJP master cylinder and a chinese slave and braided line designed for a pit bike of all things, works faultlessly
    The 165 has a magura setup taken from a RM 250 that was a direct fit and has also been faultless
    The AJP setup has a lighter pull than the magura. its so light some people think its not connected :thumbsup:
    huskybear likes this.
  3. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    My KTM has a Magura on it and my Husky has a much lighter clutch pull. I've alos had enough problems with the hydraulic system failing that I wouldn't go out of my way to add one to any bike. Jut my $0.02.
    jmetteer, MotoMarc36 and huskybear like this.
  4. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Could not agree more - hydraulics do fail, my TM had a weepy slave, think it took all of 5 minutes to pop a new seal in there so no big deal
    every other bike I have owned with a hydraulic clutch gas gas beta husabeg ktm I have never had a failure nor have I had a clutch cable snap since 1978 (SWM)
    The only reason I choose to use them is I have rather large hands so the adjustable span ect suits me better
    The little Husky dosnt need a hydraulic clutch and im lucky enough to have a few units laying around so have not had to purchase any items, My mate Trig has one on his 125 as he likes mine so much but always carries the old lever and cable with him as do I at any enduro or H H event as it takes minutes to swap back if any thing should go pear shaped
    Kelly runs one on his 165 so his view may help anyone decide if its worth the purchase price :thumbsup:
  5. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    There is no lighter cableclutch pull in the world than a modern Husky 125/144 !! For some reason I prefer the organic feel of a cable clutch, hydralic always feels vague or grabby to me while slipping through corners.
    jmetteer likes this.
  6. old3 Husqvarna
    NJ
    Oh man, my 2009 EXC570 BB with a 9.0 Magura and Midwest Mountain Engineering lever is like pulling a hot knife thru warm butter. It uses the entire lever travel to disengage but once you adjust to that it is magic. It makes my WR125 lever feel heavy.
  7. huskybear Husqvarna
    B.C. Canada
    Thanks for the replies, I agree that the cable clutch has a very light pull on the 125/150. I just had the brembo clutch master laying around and was wondering if any-one had done the conversion and their thoughts on it. I will probably stick with cable system(it's simple and it works!)
  8. Pedec Husqvarna
    Sask.Canada
    My 2008 cr125 husky has the best clutch feel of any bike I have ridden and last, on orignal plates still even with 165 kit. I also own a 2012 KTM 250sx and had 2010 tc250 and would not trade for those clutches.
  9. sabortooth No Class
    Izard Co. Arkansas
    11uptite167
    The master cylinder would be of great value to someone wanting to setup a lhrb.
  10. huskybear Husqvarna
    B.C. Canada
    I will probably keep it as a spare for my husaberg.
  11. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    I rode my KTM 200 for 10 years without touching the hyd clutch and had zero issues with it. On my 250 I've had the master cylinder, slave cylinder, and hyd line all fail on different rides. I got so fed up I put a Rekluse in it.
    johnnyboy likes this.
  12. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    the clutch pull on my 165 is a simple 1 finger affair, Call your finger from index to pinky it does operate with ease and not soggy
    I had the experience ones on a KTM sx 125 with hydraulic and it was not lighter (lets say equal but spongy in feeling)
    could be lack of maintenance on it (old oil or so)
    Robert-Jan
  13. racer726 Husqvarna
    Unionville, MI
    I will never go back to a cable clutch. I don't know how you can ride a 3 hour hare scramble on a small bore without one...
