I am Fxxxing pissed !!
Discussion in '610/630' started by STANIMAL, Aug 14, 2013.
  1. STANIMAL Husqvarna
    Chicagoland
    SMS630
    WXE260
    Is it me or are the 630's sub par ? Just came back from a ride (barely made it home ) my hydraulic clutch went out again ! Aside from going out at 1k miles , this one went out at 1400 miles . I bought this bike thinking that crap like this has been sorted through the 610's years of production and testing .
    As much as it pains me to say this , why doesnt Yamaha bring the wr450x to the states ?
  2. organ donor Husqvarna
    Berlin
    Looks to me to b e one-off. Never heard of that happening.
  3. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    My master cylinder leaked a lot. Replaced it once and rebuilt the new one. Seems to be holding up so far, but the 630 doesn't get as many miles now that I have a second bike.
  4. STANIMAL Husqvarna
    Chicagoland
    SMS630
    WXE260
    I am guessing Husky didnt do anything about it ?
  5. Coffee CH Owner
    Does that bike have the standard Bremo brake the other Husqvarna's and several other bikes have?
  6. LandofMotards Moderator
    Colorado
    2014 TC250
    What do you mean it went out? Lost all fluid? It's a hydraulic clutch couldn't it just need bled?
  7. RDTCU Husqvarna
    '11 630SMS
    Yep.
    I'm around 11k miles on my SMS, only real problem was my fault for dumping on the shifter and bending a shift fork.
  8. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    610's had cable clutches. 7602 now has clutch slave pistons for the 630. Try one of those with some fresh Magura blood mineral oil and you should be good. Are you using mineral oil in the clutch?
  9. Coffee CH Owner
    I failed.
    While true the brakes have nothing to do with the issue.
    The issue is a clutch on a 630, which presumably is a Magura. I'm fairly sure as XLEnduroMan mentioned, the earlier versions of that bike had clutch cables, and the 630 had hydraulic Magura clutches, and I am also fairly sure 7602 designed an after market slave for a reason.
    http://www.cafehusky.com/threads/630-clutch-slave-piston-added.34231/
    I would call 7602 and get their input after you determine if it is a slave or master cylinder issue.
  10. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    Problem is that nobody can offer any type of assistance because he just said "my clutch is broken."
    We don't know if it's the hydraulics, or the plates, or if he broke the lever.
    And, he said it "went out" before, but gave no insight to what happened or what he did to fix it.
    Coffee likes this.
  11. STANIMAL Husqvarna
    Chicagoland
    SMS630
    WXE260
    Its the hydraulic clutch . The slave went out and I just ordered a Zip Ty unit .
  12. STANIMAL Husqvarna
    Chicagoland
    SMS630
    WXE260
    I ordered the whole slave , just need to use my existing piston . And yes , I only use the Magura fluid. Just frustrating to deal with crap like this when a bike has 1400 miles on it .
  13. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
  14. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    It was under warranty for the replacement. The rebuild was on me, as the warranty had expired.
  15. STANIMAL Husqvarna
    Chicagoland
    SMS630
    WXE260
    Ouch , 92 quid plus VAT and shipping .
  16. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    About what you will pay for a 7602 piston and a Zip Ty Slave, am I right?
  17. organ donor Husqvarna
    Berlin
    Just a speck of grit could have been the cause of that. And if it´s a faulty unit ... blame the Krauts at Magura. I didn´t want to keep the Mickey Mouse reservoir on the bar so I changed to a box type Magura unit. Result was that I couldn´t ghet ASV grips that fit. .
  18. RDTCU Husqvarna
    '11 630SMS
    Which reservoir?
    On the SMS, the clutch is a box res and the brake is a remote round plastic res.
  19. STANIMAL Husqvarna
    Chicagoland
    SMS630
    WXE260
    No , thats about $200 , the Zip Ty is $100 .
  20. EricV Husqvarna
    I hear you man...it is frustrating so more than understandable. I love the 630- don't get me wrong there, it's more than a pleasure to ride- and I of course expected it to be a little more issue prone compared to an Asian bike. Still, in the first few thousand miles I also didn't expect to have an issue w/ the hydro clutch, nor an issue w/ a fraying/frying wiring harness (section of it), nor a leaky radiator (and leaks here and there in general), sprocket bolts coming loose, head bearings needing immediate attention, clutch washer issues which are bound to emerge, etc. Now of course not all have all of these issues, but the recurrent theme is that most do. I just expected/hoped it wouldn't be quite as prone to niggling issues and, in the big picture, banking on it being most durable where is counts most- the engine/trans itself (in terms of durability/longevity w/out major issues.) In the end I still deem it as worth it- the bike is a blast and no other dual sport I've had closely compares to it in terms of great power to weight ratio, torque and in general great all arounder status.
