250-500cc I have a problem with my WR300 2012 year.
Discussion in '2 Stroke' started by Murda_man, May 3, 2012.
  1. Murda_man Husqvarna
    WR300
    Guys,
    I have a problem with cold and hot starts (10-15 kickstarts) and my bike often "kick back" strongly when I am starting it. And I watched rich symptoms. Yesterday, I went fast and when I was 5rd gear and full throttle, my bike is stopped. I think the fuel isn't fired and the plug was dirty.
    I think I have a problem with Adjusting the timing(ignition), maybe my bike have advance ignition, I want to "retarding" the ignition.
    Perhaps I had a problem with float level ( when my bike side stand my carb is drop) and I reduced the float level of, but the problem repeat.
    Carb: Mikuni TMX 38
    Main jet - 430
    Pilot - 45
    Needle - "GAY"
    Clip position - 3rd
    Slide - 4"
    Air screw setting - 2
    Elevation (feet) - 0-500 ft.
    Please, help me.
  2. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    2013 HUSABERG FE 350 ,2014 KTM 300XC
    HAD THE SAME PROBLEM WITH MY NEW 2011 I KNOCKED MY BRAINS OUT !!! THROW THAT MIKUNI IN THE GARBAGE !!! call JD Jetting or motosportz and get the Keihnin PKW !!!
  3. Murda_man Husqvarna
    WR300
    My friend have WR300 2009, he hasn't this problem with Mikuni. I'm from Ukraine, call JD Jetting or motosportz and get the Keihnin PKW - it's difficult.:cry:
  4. Murda_man Husqvarna
    WR300
    Do you try to change the spark advance?
  5. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    i had no luck with the Mikuni.......... sorry i couldn't help. its not the ignition although it acts like it is....
  6. lankydoug Husqvarna
    MO
    WR
    TM 300en
    My guess. Cold start the pilot is too big, I use a 27.5 pilot at 1500 feet above sea level. A 30 pilot would stutter off idle but at 500ft you may be able to use a 30.
    Wide open throttle problem is most likely float level too low or needle sticking and running the bowl dry. I modified my bowl plug/well to help with fuel getting to the main jet. I'm not sure how much it helped but my Mikuni runs perfect with nearly the same settings. 430 main, 27.5 pilot GAY needle in 4th notch (one step richer than middle).
    The bowl mod is as follows; drill 4 or 5 small holes in bowl plug on land next to the threads so the fuel can fill directly in to the well instead of having to spill over the rim of the bowl.
    454x likes this.
  7. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    I agree with the rich pilot theory. My 11 starts like a dream when the pilot is correct........
  8. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I put the #40 in my 300, but it seems like it could still be a bit leaner and cleaner running off the bottom.
  9. Murda_man Husqvarna
    WR300
    My friends,
    Thanks for yours comments, but how can I comment that my bike often kick back strongly when i starting it? It seems that my bike have advance the ignition.
  10. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    take off the ignition cover, there should be 2x 8mm bolts holding the stator plate in position when you remove the bolts you can see the timing marks, with the bolts removed (or loose) you can rotate the plate (clockwise advance) most people run3 degrees advance to markings, retarding helps top end rev.
  11. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    2011 and 2012 have digital ignition...................................
  12. Murda_man Husqvarna
    WR300
    2009-2010 - IGNITION
    Capacity discharge electronic start with variable advance.
    2012 - IGNITION
    Type.. . . . . . . . . . .electronic digital capacitor-discharge
    type, with variable advance
    I think, that it means an adjustable.
  13. Motosportz CH Sponsor
    Change your pilot one of two sizes leaner first. Than see whats up. I would not chase other stuff, I think it is your jetting. The stock carb can work fine on those (the 125 is harder) but if you get absolutely frustrated with it we can ship you a carb internationally, do it all the time. They do seem FAR EZer to jet and maintain.
  14. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    You may be right. I have not messed with mine. I can tell you that mine used to kick back and be a bitch to start untill I lowered my pilot and got the air screw correct......
  15. Murda_man Husqvarna
    WR300
    Guys,
    why is this man have a same jet kit and his bike starts and runs great?:confused:
    WRSteve wrote:
    Year & Bike Model = 2011 WR300
    Carb = Mikuni
    Pipe & Silencer =Stock
    Other engine mods = none
    Premix ratio & fuel type = 50:1 Maxima 927 91 Octane pump gas
    Temperature range (deg F) = 45-70 degrees F
    Elevation (feet) = altitude is usually between 500ft and 2500ft
    Main jet =420
    Pilot jet = 45
    Needle = "GAY"
    Slide = stock??? it says 5 on it and everyone talks about a number 4 slide
    Clip position = 3rd clip
    Air screw setting = 1 1/8
    wait4me wrote too:My bike seized on this jetting.
    Maybe I can't adjust the air screw correct?
    My Air screw setting = 2
  16. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    I can tell you, you have to kick it like you mean it. The only time I get a kick back is if I am in an awkward position (stalled on the side of a hill) and can't get my weight on it.
  17. Murda_man Husqvarna
    WR300
  18. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    I'd bet on a too rich pilot circuit. I'd drop the pilot to a 40 and airscrew at 1.5 as a starting point. My '09 300 was sensitive to pilot jetting about would launch you to the moon if the pilot circuit was too rich.
  19. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    I have a #40 and the air screw at 1 3/4. I think I need to drop down another size or so.
    Mine also kicked back when it was had the wrong (really lean jets and slide) in it.
  20. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    Murda, maybe you should take one of those ladies from the video with you when you go riding. For being inexperienced they seem to get it lighted off pretty quickly!
